Amperage and MAH how is it doubled ?
SpeedAssault
SpeedAssault's Avatar
Amperage and MAH how is it doubled ? - 05.16.2009, 02:28 AM
I have done a lot of reading and have not seen a FAQ sticky on this.
I am very frustrated just trying to figure out what size lipo I NEED for my new project car. (Castle Monster combo 2200kv) 9 lbs car, 4WD, mostly street bashing speed runs and rally hard pack driving, speeds in 50's
The big problem is I read and hear different stories about Series and Parallel.
Hobby shop owner says if it's in Series "everything is doubled, including amperage
Another guy says if it's in parallel the MAH it's doubled.
For Example Two 3s 3000mah 30c lipo in series becomes 6s 6000 60c.
flip side Two 3s 3000 30c in parallel becomes 3s 6000 30c.
SO I ask you guys What is the true answer on this and where is the calculator to figure what continuous amperage do I need to run ?
Another confusing lipo issue is one lipo will say 30c at 67amps and another will say 30c at 81 amps.
I was told it depends on how many cells are in series or parallel in the battery. Problem is many batteries onle say C rating.
Castle creations told me they recomend that I run 33c for my setup. But what is the true amperage and if putting lipos in series is best then what C / amp do each batt. need?
Appreciate the help
05.16.2009, 02:38 AM
Ok...
Series involves linking all the cells plus to minus. So the entire pack spec will mimic a single cell. So a 6s or 2 3s packs wires in series is the same thing.
eg, 6, 3000 30c cells wired in series will give you a 6s 3000 30c pack.
Parallel wiring takes 2 sets of X number of cells wired in series and wires both pos and neg of those X number of cells together.
eg, you have 2, 3s 3000 30c packs and after you wire them in parallel you will have 3s 6000 30c.
C rating refers to the ability of the cell to produce amps. It is simply a number that you multiply by the pack's amp capacity rating to determine what the pack can output.
eg, the 3000mah 30c pack can output 90amps. You get this by multiplying the 30c by the packs AMP/hr rating (3000 milli amp hour-mah = 3 amp hour)
So 30 x 3 = 90
So you see that the packs capability is related to both its capacity (mah) and the C rating. Voltage is not important when doing the math for pack amp discharge.
Total available power is determined by finding the discharge capability (as shown above) and multiplying it by the pack voltage.
So our 6s 3000 30c pack would be capable of 1998 watts. 22.2v (=6s) x 90amps = 1998 watts.
SpeedAssault
05.16.2009, 03:08 AM
Ok...
This does not look right. Parallel is - to - and + to + voltage the same but twice the run time.
So 30 x 3 = 90
Thank you lincoln
I know about series and parallel wiring
But now you have lost me with the watts at the end. SO I Multiply Volts X Amps to Figure Watts right ?
Just need calculation for KV into Watts
The hobby owner was showing me how he was just put in Garage magazine for being the first hydralic guru for low riders and how his Slot car track runs on car batteries in parallel. So I wanted to believe him.
squeeforever
squeeforever's Avatar
05.16.2009, 03:21 AM
Thank you lincoln
But now you have lost me with the watts at the end. whats the amperage ?
Yea, he was definately wrong.
The only somewhat confusing part of all of it is parallel. 2 3S 3000mah packs in parallel will be 3S 6000mah, like pimp said, but it would still be 30C. Differance is, the amps double as well, just not the C. Its pretty simple one you think about it. A 3S 3000mah 30C pack is 90 amps, but a 3S 6000mah 30C pack is 180. Still 30C, but when the MAH is doubled, so is the amperage since C x Ah = amps. Got it?
SpeedAssault
05.16.2009, 11:27 AM
Thank u squee,
Wow , thank you for putting it into that example, it makes more sense and easy to folow.
But that is weird to figure, that MAH double and amps double but not the C rating. I thought the C rating had to do with the amp output..?
So what importance is C rating, how is it used ?
How about in series, whats that equation ?
I may want to use two 3s in series
thank you for your help, it really
JThiessen
JThiessen's Avatar
05.16.2009, 12:09 PM
In laymans terms...C rating is basically like the valve size on your garden hose. You can change how fast the fluid goes through it (Amps), and you can change the pressure behind it (Volts), but that valve is always only going to open up so far, thus only allowing so much water through....
05.16.2009, 01:09 PM
Watts is pretty easy, it is just volts x amps. Watts are a good indicator of total power available.
You can figure that a vehicle of a certain size and weight will draw X number of watts. Main issue is figuring what wattage you need to get the job done. It is usually best just to post up the setup you plan to run and the desired result. The the rest of us who had done something similar can offer insight.
More example:
say you want 2000 watts, and plan to run 4s - 2000/14.8 = 135.13 amps. If you figure that is what you need at the tires, and the motor is 85% efficient, you will need about 2353 watts from the battery to get the job done - 2000/.85 = 2352.94, or you can take the 135.13 amps/.85 and get 158.97 amps needed from the battery at 4s.
So as you can see, to get 2000 watts at the tires with and 85% efficient motors you will have to have a 4s pack capable of 150 amps, so a 5000mah 30c lipo should do the trick (as long as the specs are true to the pack's performance...).
Tire weight and vehicle weight play the biggest part in figuring the amp draw a system will determine. You have to move the chassis weight around with the motor, so it stands to reason that lighter is better. Wheel weight is also a big factor, as a heavier wheel/tire will need alot more power to get moving that a smaller lighter tire. That is why we can get away with smaller lower torque motors in buggies, while truggies/MT need a big torque motor to get those big tires moving.
MetalMan
MetalMan's Avatar
05.16.2009, 02:42 AM
It's hobby shop employees/owners like that who set up such views of ignorance regarding ALL other hobby shop employees. linc certainly straightened this out.
squeeforever
05.16.2009, 11:13 PM
You might not need 30C. That would depend on the mah of the pack. And to answer your question earlier, the C rating refers to the cells. a 3000mah 30C is still gonna be a 30C cell no matter how many there are. Thats gonna be 90 amps, but if you put 2 in parallel, that will the 6000mah. Still 30C since the cells haven't changed, just the number of them. 6000mah 30C would be 180 amps. Get it? Its still 30C since thats what the cells are rated at. The amps just raises because the mah raises since there in parallel.
05.16.2009, 11:56 PM
I can see bursts of 1250w. Around 250w is much more common for average power draws in truggies/MT. After all, 1250w on a 6s 5Ah battery will only get you about 5 minutes of runtime...
05.17.2009, 12:25 AM
I got 1250 (more like 1500) bursts in a buggy, but average draw for that was around 30 amps.
SpeedAssault
05.17.2009, 04:02 AM
If you think you need 1250 watts of power to the wheels and you plan to use a motor that is 85% efficient then you will need some thing like 1500 watts of battery power
1250/.85 = 1470
Now the problem iswhere did you get the 1250 from? Someone told you that? Doing the math will get you the numbers, but there are no hard and fast rules on what numbers apply to what vehicle due to the giant amount of variables.
Best to list your setup and intended use and we will do our best to suggest alternatives for lipo power.
I did a search and read that the CC 2200 is 1250 watts and yields 85% efficient.
I dont know the math. But I did just learn the math to get watts from battery.
My setup (pic Below and in my sig)- in middle up drivetrain upgrade so dont look to close, the front is done though.
Custom 4wd 1/5 car (9.lbs no battery), Losi 43/13 ring pinion with a losi 2.0 CD but locked with a 45s/16p, locked rear, 5" tall 1/5 scale FG street slicks and working on a way to swap wheels out for very mild dirt 3.3 tires (4.5-5") for hard pack rally driving, but mostly street stunt, bash drifting , CC Mamba Monster /2200
want 45-55mph and 20 minute minimum runtime
that is hard to believe/understand that 5000 6s only run 5min.
I have been trying this car out with my mamba max, Thunder P 3s 2250 30c with a Feigao xl 2383 and it drives for 15 minutes until speed of 28mph starts dropping. that was with a Emaxx tranny locked in 2nd and 1/8 street slicks
what are you referencing ? dont follow you where u coming from ?
Really really appreciate everyones help, keeps me from going crazy
ID:	7015   Click image for larger version
Patrick
Patrick's Avatar
05.17.2009, 06:50 AM
Brian's saying that at 1250w CONSTANT a 6s 5000 mah would only last about 5 mins. He meant that it is not a realistic amount of power to use constantly, only in bursts, that's why he said 250w is a more common average power draw in truggys. Which would equal about 25 minutes max runtime from 6s 5000mah (111 watt hours total). Don't know exactly how your car will compare for power usage.
What voltage do you intend to run that car on? If you want run 6s on that motor you'll have to use a smaller pinion than 16t or you'll be geared for over 65 mph.
Don't concentrate too much on the motors 1250w rating, it doesn't mean much for real use. It doesn't mean you'll use 1250w constant, it doesn't mean you'll never use more than 1250w, it just means the motor is rated to handle 1250w. How much power you really use will depend on many factors, but basically the more load you put on it the more power it will use.
05.17.2009, 11:07 AM
... that is hard to believe/understand that 5000 6s only run 5min.
Yup, Patrick is right, that's what I meant. If you are running for 15 minutes on 3s 2250mAh cells, this is what your setup is doing:
- Average amp draw is 9A.
- Your estimated burst amp draw is around 65A.
- Your average power is 100w
- Your estimated burst power is around 700w.
The figures make sense given the weight and gearing of your setup. If you geared up and/or made the setup heavier, your amp draw would increase and runtime would decrease.
SpeedAssault
05.17.2009, 12:15 PM
[[[ First I would like to Say that all you guys are really nice to give your time and help on this and it is greatly appreciated.
? ? ?My SETUP. please tell me what you recommend from your experience and if you could tell me how to do the math.
want 45-55mph and 20 minute minimum runtime ? ? ?
[Quote reply]
oh ok, I get it, it was about being a constant draw.
I'm not sure whether to go with a 2s and 3s in series or just Two 3s in series.
But I like the idea of split weight.
I was shopping for Batt, one site site listed it's C rating and the other site only listed is constant amperage of 75, at the time I did not know how to calculate to see if they were the same and also one battery was a EP and the other did not say and I was going to put them in parallel, by the time I got the answer the 2nd batt was also a EP he told me I should run a NP .So this battery shopping has been a Long confusing deal.
Here;s the lipo's I was looking at :
NeuEnergy 5S-1P 2500
NEU2500EP 5S1P V1 -->http://www.neumotors.com/Site/Battery_Info.html
But I have read and heard that its best to run in series
So it's either a 2s and 3s in series or Two 3s in series
