RPM true track pivot balls keep pop out -
05.25.2009, 01:21 PM
Need help to solve my problem with the pivot balls keep pop out of my RPM true track.
NeuMaxx
05.25.2009, 01:54 PM
Sounds like you stripped the arm. I have heard of the pivot ball pulling out of the axle carrier but not the arm. If you stripped I'd get a new arm.
05.25.2009, 03:00 PM
Thanks mkrusedc it's the "ball pulling out of the axle carrier", sorry
05.25.2009, 06:42 PM
Yup - Thats why i binned RPM Knuckles!
05.25.2009, 06:58 PM
binned? not following
05.25.2009, 07:03 PM
Maybe trash "bin"? Or parts "bin"?
05.25.2009, 07:13 PM
05.25.2009, 07:48 PM
05.26.2009, 09:46 AM
Thats nice, but you're from NJ, most comments in the link are European.
05.25.2009, 08:28 PM
Those Tekno axle carriers are the best.
Or you could use a set screw to keep them in, like Mistercrash did on his ERBE.
NeuMaxx
05.25.2009, 09:31 PM
You can get the Platinum Revo knuckles. The have a retention ring built in to them or you can cut a piece of brass tubing and make a retention ring yourself.
(If this was covered in the links posted above sorry I was lazy and did not feel like checking)
05.26.2009, 01:36 AM
Okey but It is the true track RPM (rear) I have problem with, is there a solution for this?
Something, anything, nothing
05.26.2009, 09:32 AM
Make your own retention ring from a piece of brass/bronze tubing. A dremel tool and about five minutes should do it.
This is what was suggested in the earlier post by mkrusedc.
05.26.2009, 09:55 AM
He is British though! Like linc but without all the weird cross-dressing stuff.
05.26.2009, 09:56 AM
He should have picked up Jersey talk by now...
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
