Inferno GT 4s. What is the best setup to go to 60 mph ?
NikoIGT
Inferno GT 4s. What is the best setup to go to 60 mph ? - 06.22.2009, 08:55 AM
Hi,
I want to convert my inferno gt with a good setup, about 60 mph, with a good runtime (greater than 15 minutes).
Suggestions?
06.22.2009, 09:20 AM
I'd say CC 2650 and 6000+mah bats should do it..
NikoIGT
06.22.2009, 09:34 AM
Ok, and gear ratio ?
06.22.2009, 09:51 AM
Use this and bookmark it...
http://scriptasylum.com/rc_speed/
NikoIGT
06.27.2009, 05:06 AM
OK, what is the best setup?
1 speed setup:
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 15
Total Voltage: 14.8
Motor KV: 4500
Tire Diameter (inches): 3.54
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 3.07 : 1
Total Ratio: 10.14359 : 1
Tire Circumference (inches): 11.12 inches (282.48 mm)
Total Motor Speed: 66600 RPM
Vehicle Speed: 69.15 mph (111.07 km/h)
Effective KV Value: 4500
KT constant: 0.3 oz-in/A
2 speed setup:
Other Ratio: 1
----1 gear
Spur/Pinion Ratio: 3.06: 1
Total Ratio: 10.14 : 1
----2 gear
Spur Tooth Count: 40
Pinion Tooth Count: 21
Spur/Pinion Ratio: 1.9 : 1
Total Ratio: 6.30037 : 1
Total Voltage: 14.8
Motor KV: 2600
Motor coil O: 0
Total Motor Speed: 38480 RPM
Vehicle Speed: 64.32 mph (103.32 km/h)
Effective KV Value: 2600
KT constant: 0.52 oz-in/A
aqwut
Brushless Heavy Weight....
aqwut's Avatar
06.27.2009, 09:16 AM
Here's my setup.. 60+MPH and about 15+ minutes easy.
6S1P PolyQuest XP 25C 3700mAH, 1400 KV motor, MMM ESC, 46T Spur, 22T Pinion.
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
NikoIGT
06.27.2009, 12:37 PM
But "R/C Calculators" estimated 45mph with your setup.
aqwut
aqwut's Avatar
06.27.2009, 01:53 PM
mine's a buggy... I didn't realize the Inferno GT was a touring car.. my bad..
