Revo Hybrid Diff Case/v3 bearing size?
titan
titan's Avatar
Unhappy Revo Hybrid Diff Case/v3 bearing size? - 06.22.2009, 03:55 PM
Hello,
i search for the info long time.
What size are the ball bearings for the input shaft at the new case?
I need this info :) My aluminium cases has 12x6mm bearings - too small i think.
Thank you
Titan
06.22.2009, 05:22 PM
I believe they are 12x8 but not 100% sure
titan
titan's Avatar
06.23.2009, 04:38 AM
Thanks.
Somebody know it 100%? It is money so need to know it. :D
Titan
PS Is it the wrong forum? :)
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
06.25.2009, 12:18 PM
Looking at the pic of the different parts of the Hybrid Diffs, it really looks like the input shaft is 8 mm with the tip machined to accept the Revo shaft. I'm sorry I can't be 100% sure but it really looks like you need a 12X8 bearing like magman said.
No brain, no headaches.
titan
titan's Avatar
06.25.2009, 12:42 PM
Mhh but what change on V2 and V3? I wrote mike a mail, but no answer.
Titan :/
06.25.2009, 04:18 PM
Titan :/
The v2 uses different size diffs...HB Koysho, etc and hence different size bearings. The v3 uses Mugen diffs
Urgeoner
Urgeoner's Avatar
06.25.2009, 05:30 PM
I can tell u the size but I'd have to open up my diff first..12x8 sounds right though
titan
titan's Avatar
06.25.2009, 06:16 PM
Mhh Okay, so i order only some 12x8er Ball bearings and replace them often.
Thank you. Nothing chances on case - so i can use the old one.
Titan
