Brian G, Wiring diagram help.
prhess
RC Addict
Brian G, Wiring diagram help. - 06.24.2009, 12:25 PM
Hello Brian,
I was wondering if you can help me with a wiring diagram. I want to use a multimeter to measure my amp draw on my power supply. I am using an integy power strip to connect many DC devices to my 16amp power supply. I know that the meter has to go in series in the connection....but I do not know how/where to tap into my set up to read the total amp draw off the power strip. Can you please help. I have an extra good quality digital meter that I would like to put to good use.
Thanks
Peter
If you can't be good, be bad!
06.24.2009, 12:34 PM
OK, follow these steps:
1: Set your meter to ammeter mode. It probably has a special high current jack, so you'll need to use that one.
2: Plug the red meter lead into the high current jack on the meter.
3: Plug the black meter lead into the "common" meter jack.
4: Disconnect the positive wire that connects the power supply to the power strip.
5: Hook the red meter lead to the positive wire on the power supply.
6: Hook the black meter lead to the positive wire on the power strip.
(Actually, the meter lead order doesn't matter; if you hook them up backwards, you'll just get a negative current reading).
The meter should now be IN SERIES between the power supply and power strip.
7: Turn the meter on.
8: Turn the power supply on.
9: Hook up your load and have fun measuring.
prhess
RC Addict
06.24.2009, 01:59 PM
THANKS FOR THE HELP
