Mmm lost power but dont know why
twisted8
Mmm lost power but dont know why - 07.17.2009, 11:10 PM
last night at racing i came off a large jump and truck shut off, it had no power at all,no steering etc..i thought it thermaled because when the marshal put it down it powered back up .
couple of laps go by and on the same jump truck looses power again. this time it doesn't come back on. i go tothe pits un plug every thing and plug it back in (no on/off switch) and it works. i then wiggle all the wires and i get it to turn off and on once but can not get it to do it any more.
the plugs look and feel like they are tight,the batterys work fine (tried in another truck) im gonna change the connectors just in case on the esc and those two packs.
anyone hear of any problems with the esc that sounds like this ?
its in a e revo running a 2200 4s 40c 5000 packs. no error lights. just lost power. i know it sounds liek a loose connection but i can not get it to do it again.
thanks.
brushlessboy16
brushlessboy16's Avatar
07.18.2009, 12:05 AM
remove the switchc. then from there make sure nothing came undone from the main board
twisted8
07.18.2009, 01:02 AM
don have a switch as i stated in the above post. doesnt opening the case void warranty ?
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
07.18.2009, 11:39 AM
Are you sure it's losing power and not signal from rx? If your radio has weak batteries and loses signal that would do it, then when you get close enough for signal it re connects and works
twisted8
07.18.2009, 02:20 PM
batteries arent low in transmitter . plus wouldn't the truck still stay on ? there was no power,no lights on the esc or personal transponder.nothing.
im still confused...lol
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
07.18.2009, 07:18 PM
switch. gotta be, i had the same issue for a bit...ended up making a "key" with 2 JST plugs to short out the switch wire.
  Send a message via MSN to shaunjohnson
twisted8
07.18.2009, 08:19 PM
took out the switch a long time ago.
Andrew32
07.19.2009, 01:36 AM
check for bad/broken or cold solder joiints in the power connectors. gotta be the battery connectors or the MMM. Then see if there are any you can see on or feel on the MMM itself
07.20.2009, 12:25 PM
+1 for a bad connection or joint somewhere, though it may indeed be inside the esc- process of elimination.
twisted8
07.20.2009, 03:03 PM
well i went racing yesterday and after changing the esc plugs and battery plugs i had no issues at all.even though the plugs fet tight must of had a bad connection thee i assume..
thanks for all your help guys .
