Bad MM?
BLBuggyBoy
Bad MM? - 08.12.2009, 01:19 AM
Hi i have a MM lying around and when i turn it on all the LED's blink, does this mean that its bad?
08.12.2009, 01:47 AM
If they all blink really fast it means the ESC is in LVC mode. Chances are you set the LVC for a certain voltage and you are using a lower voltage pack, or something like that.
BLBuggyBoy
08.12.2009, 01:53 AM
im actually using 4s, and its a fully charged pack, i set it up for 4s
BLBuggyBoy
08.12.2009, 01:54 AM
I should also note that its duty was on a revo, feeding a Neu 1515/1y on 4s
Pdelcast
Pdelcast's Avatar
08.12.2009, 10:40 AM
Which LEDs blink? It could just be waiting for arming, or need to be recalibrated.
Patrick del Castillo
President, Principle Engineer
BLBuggyBoy
08.13.2009, 12:09 AM
the green, yellow and red all blink togather about 5 times a second which is pretty fast, but idk how the LVC could be kicking in when im using a fully charged pack, i even checked the voltage with a little individual cell voltmeter that plugs into the balance port and it said 16.80V. Unfortunatley i can't find my castle link CD, it was installed on my old computer but it crashed, but i remember setting the ESC for 4s LVC when it was being used. i hooked it up to a reciever but not to a motor and the LED's didn't respond to throttle or brake inputs.
eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
08.17.2009, 03:48 AM
you can download the castle link from castle's download page. I'd put the latest firmware on there, auto lipo 3.0v/cell. I would also plug into a motor. if it beeps once or twice a second, it is has no signal to it, which could signify a broken reciever.
Link: http://www.castlecreations.com/downloads.html
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
