Looking for single place for these parts...
Looking for single place for these parts... - 09.21.2009, 06:07 PM
Since I'm having no luck selling my TP balancer (and I refuse to sell at that thieving ebay place), I decided to make it into a general purpose balancer. But I can't seem to find a single place that has both of the items I need. I hate spending $5 for shipping for a $1 part, times two. Anyway, the following is what I need:
1: Thunderpower 6-pin (5s) balance connector/pigtail that will plug into a Thunderpower balancer. These would be the same connectors as you would find on the battery pack. Would prefer to have wire pigtails already attached.
2: Snappable header pins, like this. Would prefer the right angle style, but straight would be fine too.
TIA!
JThiessen
JThiessen's Avatar
09.21.2009, 10:42 PM
I'd try cheapbatterypacks.com - they have a pretty good selection of building supplies.
09.21.2009, 11:01 PM
allerc.com
ksb51rl
09.22.2009, 12:09 AM
Possibly www.hobbydream.com, but they're on "holiday" until Oct. 6, and the website just says "debugging" at the moment.
09.22.2009, 01:08 AM
Well, the first two didn't have what I was looking for, and not sure about the last one until they come back. Thanks anyway guys!
09.22.2009, 01:42 AM
Just sent an email to TP to see if I can get the pigtails I want direct from them. Anything I've found online would require modification to the connector to work.
OZ-RUSTLER
OZ-RUSTLER's Avatar
09.22.2009, 02:18 AM
How about http://www.rclipos.com/
10.03.2009, 02:42 PM
Well, I got the parts I was looking for. The only place I could get all the TP connectors I wanted was a place I do not want to do business with, so I went directly to TP. Paid a few more cents per cable, but that's ok. And then, I got the headers from allelectronics.com. To make the shipping cost worth it, I got a few extra goodies for future projects.
The whole purpose of this was to make 0.1" spacing balance tap adaptors, but use the TP210 balancer. This balancer has a 450mA balance rate, so balancing is done quicker. And, it seems to be the most accurate at determining actual imbalance.
Here are a few items I got:
And what I made with it:
Made a 6s balance adaptor and a 5s adaptor. I cut little squares out of the PCB, layed the header pins on it, and soldered them. Then it was a simple matter to solder the wires on the PCB as well. The PCB is not needed, but tends to help support/strengthen the pins. Also in the pic is a balance tap break-out board for experimenting, charging/discharging individual cells, etc.
10.03.2009, 05:57 PM
Slick...glad we have an electrical guru around here
J57ltr
10.03.2009, 07:16 PM
Well It's a little late, but I actually stock those 40 pin headers. We use them to split into 10 pin headers for mounting another board on top of a motherboard we make.
Jeff
