revo brushless project help
davey2395
revo brushless project help - 09.23.2009, 04:21 PM
hey.i'm new here but need help.i'm building a brushless revo 3.3 with the old emaxx trans and need to know which center cvd's to use.i will be running a novak hv maxx.
09.23.2009, 04:26 PM
Welcome to the forums!
I don't believe there are any "out of the box" shafts you can use. So, you'll need to get custom shafts and drive cups from Mike here at RCM, or wherever you prefer. Wherever you go, you'll most likely need to provide exact measurements.
Or, you might be able to modify Revo driveshafts to work. Just remove the booth and cut the parts down for the size you need...
davey2395
09.23.2009, 04:42 PM
i do have some measurements.from front bulkhead to trans is 125mm and from the rear bulkhead to tranny is 100mm.
davey2395
09.23.2009, 04:50 PM
anybody have any suggestions on the measurements i gave?
09.23.2009, 05:17 PM
Not too many people use the old emaxx tranny since some of the parts can be hard to find. I used it once in a Revo conversion a few years ago, but can't find the measurements I sent to Mike to make.
davey2395
09.23.2009, 05:22 PM
well should i use a revo tranny?
SV6000
SV6000's Avatar
09.24.2009, 06:34 AM
Hi Mate
I didnt use a tranny in my build so my shaft lengths are different entirely, but what i can suggest is waiting until you have the drive cups you are going to use and than taking your measurements.
http://www.rc-monster.com/forum/showthread.php?t=22158
CUBIC INCHES = CUBIC HORSEPOWER = CUBIC DOLLARS
davey2395
09.24.2009, 05:45 PM
hey sv6000 sent you a pm.i did get the front driveshaft to work from an extended tmaxx chassis.measured the rear one with cup installed and it needs to be 95mm long.can anybody measure their revo 3.3 and let me know if one of them is 95mm long?thanks and hope to have some pictures on here soon.
SV6000
SV6000's Avatar
09.25.2009, 07:13 AM
The EREVO rear drive shafts are fairly long
Sent you a PM
davey2395
09.25.2009, 09:35 PM
hey sv6000 i'm not using the erevo.i'm using a nitro revo 3.3 chassis for my conversion.i know somebody has done a conversion using the nitro chassis with the emaxx tranny.i've made battery trays for the sides using 1/8" aluminum.i also plan on using only one servo for steering.
