Power output calculation question
Power output calculation question - 10.13.2009, 11:58 PM
Hey guys, not brushless but it is a motor question. If you have a motor rated for, say, 350 watts, is that number calculated using the voltage the motor is designed to run at, and is 350 a peak wattage or continuous? These are brushed motors by the way.
Jabe
10.14.2009, 10:54 AM
If its "industrial" motor then that 350W is continous and that wattage is calculated using rated voltage.
RPM rating is with rated voltage at no load.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.14.2009, 02:13 PM
I'm not really sure on all these 'model' wattage ratings... I am more familiar with industrial ratings.
IMO, I think the 350W would be for X amount of minutes, I don't know how long, and I don't know at what voltage they refer to. It's usually a lower voltage that they give that power rating for, so the power rating might be alot higher, depending on how they rate it.
You got a link to a motor?
