90 degree bullet connector?
zviper
90 degree bullet connector? - 10.29.2009, 02:45 PM
can i drill out the side of a 6.5mm bullet connector will that work or would it be a waste?
when i shorten my motor wires on the cc 2200kv do the wires have to be the same length?
GO-RIDE.com
10.29.2009, 02:52 PM
That's what I did to mine. Be careful. Once the hole is big enough for that large wire there's not much metal left.
E-8ight - Tekin RX8 2000kv/4S
Jabe
10.29.2009, 02:58 PM
Just drill/cut ONE side out, that way you have enought contact surface.
10.29.2009, 03:00 PM
That's what I do and it works great. I've never done a ful 90*, but sometimes I make a 45* angle and it's a good compromise between an angled connector while still allowing me to get a single piece of heatshrink over it.
zviper
10.29.2009, 03:05 PM
so instead of making it 90. just grind out the bullet so i can angle it around 45?
and what about cutting my cc2200kv motor wires do they all have to be the same length?
10.29.2009, 03:22 PM
Originally Posted by zviper View Post
...and what about cutting my cc2200kv motor wires do they all have to be the same length?
Ideally, they should be, but I personally do not think it matters if there are slightly different so that they reach where they need without stress or too much slack. Mostly aesthetic.
bdebde
That's All Folks!
bdebde's Avatar
10.29.2009, 03:16 PM
I bend the wire 90 before I tin it. And yes, motor wires should all be the same length.
V0RT3X
Muggy love
V0RT3X's Avatar
10.29.2009, 03:17 PM
The bullets on the MMM are 6.5mm right? (motor has 5.5mm stock?)
PBO
RC-Unobtainium
PBO's Avatar
10.29.2009, 05:10 PM
I tried slightly different wire lengths & made no noticable difference compared to common length wires
If you're concerned about heatshrink over 90 degree bullets? try self amalgamating tape, it works very well
http://www.heatshrinksystems.com/epr...ating-tape.htm
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
zviper
10.29.2009, 05:15 PM
ok so i went ahead and just bent then and tinned them worked wonders. i dont see the problem with using shrink tube on a 90. thanks for the help guys
PBO
RC-Unobtainium
PBO's Avatar
10.29.2009, 05:28 PM
Haha...that's cause it's not 90!
Losi 8ight-T
zviper
10.29.2009, 05:31 PM
close enough lol
PBO
RC-Unobtainium
PBO's Avatar
10.29.2009, 05:53 PM
Looks nice though, think I'll do that rather than the drill out, 90 method next time
Losi 8ight-T
zviper
10.29.2009, 06:44 PM
i used adhesive shrink tube if that helps
