Exposing the heatsink on your MMM?
primus95
Exposing the heatsink on your MMM? - 11.11.2009, 12:32 AM
Hi fellow monsters,
How many of you guys have cut the top off your MMM? I'm thinking about doing mine as I am wrecking a fan almost every drive or so due to the conditions I am driving in. Can anyone recommend a way to seal the circuit board from getting dust/rocks/moisture in it once the top is chopped?
cheers
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.11.2009, 12:52 AM
Hot glue? I have a feeling this may affect your warranty...
big greg
11.11.2009, 01:36 AM
i have cut the top off of almost everyone of my monsters, and they still got warrantied, dont worry about sealing them, you will be fine
primus95
11.11.2009, 01:52 AM
thanks Big Greg. Are you running any form of fan on the ESC now or did you get a BIG reduction in cooling efficiency chopping the top?
11.11.2009, 02:12 AM
I cut the top off my V1 MMM and it ran fine with good temps. That is until it blew up (not temp related - it was just sitting there and burst into flame). Yeah, removing the fan reduces the cooling effectiveness, but leaving the fins more exposed without restriction offsets that.
lutach
lutach's Avatar
11.11.2009, 10:16 PM
I'm going to try a new heat sink and if it works like the man behind it says it will, it'll make a fan obsolete. When it gets here, I'll post my results.
big greg
11.11.2009, 05:03 AM
no im not running any type of fan, exposing the heatsink probably drops temps 10-20 degrees
11.11.2009, 04:44 PM
I hate to say it, but a case design more like the hvmaxx wouldnt be a bad thing- seal the electronics to prevent dirt and dust entering the case, but leave the fins sticking up & out of the case. If you have a solid 'curtain' fin runnig around the outside of the heatsink, you can seal the case effectively- then a fan on top the heatsink can cool it, again rather like a vxl optional item (looks better than a normal 25-30mm fan slapped ontop). Just an idea...
Cartwheels
11.11.2009, 04:55 PM
CC sells the case and fan combo for approx $12. So if it doesn't work out just buy a new case/fan. I might do the same.
I wish CC would build a heavy duty fan that can hold up to some real abuse. That would be the ticket.
Freezebyte
11.11.2009, 05:21 PM
My fan started to make groaning noises recently and I took it apart and blasted it with the air compressor and now its back to pretty much normal.
Pdelcast
Pdelcast's Avatar
11.11.2009, 07:26 PM
In the wurx!
Patrick del Castillo
President, Principle Engineer
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
11.11.2009, 07:41 PM
i'm like brian...
NO FANS!!
but i'm not gonna tamper with my MMM in any way either.
so i try and run my setup so the fan like never comes on...i cant understand why so many people are complaining about fans failing...mine always comes on when needed and is still quiet...quite strange if you ask me.
primus95
11.11.2009, 07:57 PM
Originally Posted by shaunjohnson View Post
i'm like brian...
NO FANS!!
I see no real need for a fan on 4S if geared correctly, so I agree with you there. But I would also like to keep the ESC as cool as possible , hence chopping the top.
On 5s however, IMO a fan or open case is a must, the heat generated in the ESC & motor so much greater. My motor temp goes up 20C running 5S over 4S
shaunjohnson
i pwn nitro
11.11.2009, 08:07 PM
but i run 6s
sikeston34m
sikeston34m's Avatar
11.12.2009, 12:08 AM
You're seeing such an increase in temps because you're using the same gearing.
I put together a 6S setup on an Emaxx using a heli 8 pole outrunner geared for 32mph. I was SHOCKED at how cool everything ran. This was with a MMPro btw. A good indication that amp draw was relatively low.
Motor temps and Esc temps both relate to efficiency losses. These losses stack up and create more heat as amp draw increases.
To increase the voltage and drop the amp load on the motor means more power with less heat. You must gear down to see this.
