Epa
virusss
virusss's Avatar
Epa - 02.26.2006, 05:33 PM
hallo boys when you program the esc, the EPA settings is 100% o 120%???
coolhandcountry
coolhandcountry's Avatar
02.26.2006, 05:35 PM
I set mine to 100%. If you program it at 100% leave it there or go down.
virusss
virusss's Avatar
02.26.2006, 05:37 PM
why not 120%?
Serum
Serum's Avatar
02.26.2006, 06:27 PM
No need, you program the controller the adjust to the maxximum travel. if you program it with epa on 120, he sees the 120 as 100 percent.
virusss
virusss's Avatar
02.27.2006, 04:06 AM
ah ok i understand, thanks
crazyjr
crazyjr's Avatar
02.27.2006, 08:51 PM
my XS3 goes to 125% and i set it there. Then i reset the epa for 100%, if i need more i can go up, but most places i run i can set it for 100% after i set the esc to 125% and its enough cause of lack of traction
02.27.2006, 11:04 PM
So basically, that would have the same effect as calibrating your ESC at 100% EPA, and then increasing it to 125% when/if you need it right?
HotnCold
HotnCold's Avatar
02.28.2006, 07:39 AM
yep - like a little more steering ( if you have more one way than the other for eg.)
Hows that "Hope and Change" working out for Ya???
coolhandcountry
02.28.2006, 09:17 AM
No accually it is more like programming it at 100 then droping to 80 to run. Only use the 100 when track allows. I have done this before as well. It gives you little more control over the throttle input of the car.
