Balance connector ?
rchippie
rchippie's Avatar
Balance connector ? - 01.21.2010, 10:55 PM
I bought this balance connector to charge my two 2s neu packs as one 4s pack . It says it does kokam,neu, & orion. The description says it's a xh plug. But my balance connector for my 4s neu says it's a eh plug . what do you think ?.
http://www.amainhobbies.com/product_...=Product-Feeds
REAL MEN RUN BRUSHLESS
01.21.2010, 11:16 PM
I thought we went over this on the phone? If you zoom in the pic and look at the top, you'll see it says "XH & EH"
rchippie
rchippie's Avatar
01.21.2010, 11:18 PM
OHHH i did not see that my bad . Dont laugh at me to much . Thank you for taking the time talk .
Duster_360
01.22.2010, 12:44 PM
Offhand, do know if this adapter board will connect to a hyperion adapter board cable??
01.22.2010, 12:50 PM
He doesn't (I was on the phone with him yesterday), so he's gonna get that board and also a cable specifically for Hyperion. If the board's connector cable won't work, he'll just splice in the Hyperion connector.
Duster_360
01.22.2010, 05:16 PM
Sorry, my ques was about using that balance adapter myself with my Hyperion 0610 charger.
I'd like to series charge 2S and 3S pacs (as 4S and 6S) if this would work instead of having to fabricate a serial balance adapter.
01.22.2010, 10:22 PM
yes that is what it is designed for, note that you still need to make a series connector for the main pack lead
rchippie
rchippie's Avatar
01.22.2010, 10:35 PM
Brian of the 3 2s plug sockets . I know the negitive socket has to be with the negitive deans plug . But should i use the middle socket for the positive socket or the one on the right side of the board ?.
rchippie
rchippie's Avatar
01.22.2010, 08:37 PM
I called protek today which is owned by amain hobbies . The tech said there stuff is patterened after hyperion . So it should fit . If not i'll have the hyperion plug as brian mentioned . I also asked about this board doing both xh & eh plug ends . He said it will do both . so im assuming maybe they used a slightly wider plug housing with the correct pin spacing . But im not sure . If it does not work i'll just send it back . Brian what's your opinion on it doing two different plugs ?.
01.22.2010, 09:01 PM
Originally Posted by rchippie View Post
...Brian what's your opinion on it doing two different plugs ?.
I really don't know. I don't usually take too much time getting the exact thing, so I just mod/make things as needed.
rchippie
rchippie's Avatar
01.22.2010, 09:16 PM
He said it will so we will see . If it does not work i'll just send it back .
01.22.2010, 11:05 PM
The middle one would go to the most positive pack.
rchippie
rchippie's Avatar
01.22.2010, 11:51 PM
Cool So i'll use the left one for negitive & the middle one for positive correct ?. Im just double checking . so dont laugh at me .
rchippie
rchippie's Avatar
01.25.2010, 08:03 PM
I got my balance plate today . This plate lets me balance multiple packs as a single pack . This plate does the same thing brian's y harness does . This one does both xh & eh plugs . all i did was trim the socket a little so the eh plug would go in eaiser . I will be balancing two 2s packs as a single 4s pack . Also the stock protek plug goes right into my hyperion 610i charger.
