savage21 brushless conversion
notatoy
notatoy's Avatar
savage21 brushless conversion - 02.01.2010, 06:04 PM
hi guys need your help yet again ,, converting this nitro savage 21 to brushless have most things sorted thanks to this forum confused on gearing i have the stock two speed transmission lockd in second gear . with a 47 tooth spur gear mod1 , also have a mod1 13 tooth pinion . not sure if this is correct ???????? need your input will be running 4s and 6 s best gearing options plz guys .. some have said go to a 17 tooth pinion ??? small pic of this savage thanks .
bruce750i
bruce750i's Avatar
02.01.2010, 06:39 PM
I like your gear cover. Dough!
notatoy
notatoy's Avatar
02.01.2010, 06:45 PM
yes made from my kidds play dough pot .lol.. thanks
bruce750i
bruce750i's Avatar
02.01.2010, 07:25 PM
Looks good so far. What ESC and motor are you using? Also what motor mount are you using? I just converted a Savage X without a transmission, So I'm not much help on gearing. Maybe the masters Finnster or Jthiessen will chime in on gearing. Will you be using Flux Lipo trays?
notatoy
notatoy's Avatar
02.01.2010, 08:24 PM
ok this might help .. http://www.ultimaterc.com/forums/sho...d.php?t=105970
notatoy
notatoy's Avatar
02.01.2010, 08:49 PM
the brushless system is the 150 amp exrun combo i have two of these systems and find them great the kitt is from speed passion motor mount and batt trays to be honest not worth the money , your better of with r/c monsters motor mount thanks
02.01.2010, 11:49 PM
If you tell us the motor kv we can tell you what gearing to use...
02.02.2010, 01:17 AM
that's a hobbywing xerun 4274sl, it is 2000kv.
02.02.2010, 04:03 AM
A 13 tooth pinion puts you at 42mph on 6s and 28mph on 4s. That sounds perfect to me as a starting point. Temperarure of the electrical components is what you need to know to determine ideal gearing for any brushless setup.
Gearing a monster truck for about 40mph is an excellent starting point for determining proper gearing.
I got the mph figures by using BrianG's speed calculator. He is a moderator here at RCM and has developed an invaluable tool for the r/c hobbyist. It is an easy to use tool with drop down menus for inputting your parameters. It is found in a sticky titled "speed calculator" in the brushless section.
Using it you will never have to wonder about gearing again, here's a link to it:
http://www.scriptasylum.com/rc_speed/_top_speed.html
notatoy
notatoy's Avatar
02.02.2010, 05:21 AM
thank you so much that calculator is great also much appreciated
