Battery tray help...
Losi LST2
Question Battery tray help... - 04.15.2010, 09:17 PM
Hey guys i want to run some of these ZIPPY Flightmax 5000mAh 6S1P 30C in my lst conversion that i'm working on right now...but the problem i'm having is that i can't find a battery tray big enough..
I currently have a Tekno r/c V3 tray but it's only 150mm by 50mm..so it's long enough but not quite wide enough.
i would just use some industrial velcro and velcro it to the chassis and put some battery straps around it to hold it in place but i don't want to risk a fire from a battery getting knocked around.
So does anybody know of any trays that will fit that battery?
I would order a custom tray from RCM but i can't really justify spending $50 on a custom tray.
-Austin
P.S. i've been reading TONS of threads on here since i joined and i've found alot of very good info. i'm very glad i signed up here
04.15.2010, 09:24 PM
Homebrew would be your best option really, unless KerhsawDesigns has something suitable?
Homebrew is cheap and easy though, just need a couple bits of L-channel aluminium ( 1/8" thick is plenty ), a hacksaw & files, and a velcro strap or two. Heres what I knocked up for my Zippy Flightmaxxes to go into my TXT-1:
http://i115.photobucket.com/albums/n...Mulligan93.jpg
http://i115.photobucket.com/albums/n...Mulligan94.jpg
http://i115.photobucket.com/albums/n...Mulligan95.jpg
http://i115.photobucket.com/albums/n...Mulligan96.jpg
Losi LST2
04.15.2010, 09:30 PM
wow i wasn't expecting a reply that fast...this forum really is great :)
That tray you made looks pretty good!...if i can't find a sutable in the next couple of days i might try making somthing
I'm hopfully ordering my motor, and esc this weekend because my birthday is on sunday and then i'm going to be ordering the batteries in the next little bit to so i'd like to get this truck ready for it all
Thanks, -Austin
Finnster
KillaHurtz
Finnster's Avatar
04.15.2010, 11:26 PM
IDK, perhaps cut it down the middle and secure each half to the chassis with screws? You could easily reinforce the gap with other plastic.
Not elegant, but gets the job done. I always make my own trays from ABS plastic project boxes from ratshack. Cheap and light. Never had one fail yet.
simplechamp
simplechamp's Avatar
04.16.2010, 01:13 AM
Mike can make you a tray any size you want.
Losi LST2
04.16.2010, 08:19 AM
Yea i know he can....but his trays are $35+another $15 for a custom size..
I said in the first post "I would order a custom one from RCM but i can't justify spending $50 on a battery tray"
Losi LST2
05.09.2010, 09:08 PM
Heey guys sorry to bump this back up but do any of you have the 8ight E battery tray(the one from the losi conversion), i've decided to change the batteries i'm going to use and i like the look of the losi one
If it's 150x50 that would be good
Losi LST2
05.11.2010, 10:02 PM
Common sombody must know the dimensions of the losi tray
bdebde
That's All Folks!
bdebde's Avatar
05.11.2010, 11:03 PM
looks like about 167 x 52
Losi LST2
05.11.2010, 11:19 PM
Thanks man, i knew sombody must know lol
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.12.2010, 01:33 AM
Cut some pieces of carbon-fiber large enough for the batteries, cut slots in them to run battery straps through, drill and countersink a couple holes to mount them to the chassis, and you are golden!
I did this very thing on my BL Revo 3.3 Conversion and it hold the batteries (two Zippy Flightmax 30C 4S 2650mAh LiPos in Parallel) perfectly!
-Chad
PM ME IF YOU HAVE THE BELOW:
