Hybrid bulks , what diff set fits ?
SpeedAssault
SpeedAssault's Avatar
Hybrid bulks , what diff set fits ? - 05.31.2010, 03:08 AM
Currently using LST gears 43/13 in Losi aftershock alum cases with modded Emaxx 3906 grey bulkheads, connected via losi driveshafts and modded outputs to revo universal shafts.
I need a stronger system, nothing has broke yet but I'd like a solid setup and find steel universals with 8mm stubs and change the bearings to fit tekno knuckles, unless there is something better.?)
The Losi ring gear is .38mm or .3inch larger than what FLM hybrid says will fit up to 1.5inch gear. But losi is a 1/8 gear set, so I'm confused why they say 1/8 fits when clearly it does not.
What gear sets do I have to choose from ?
I have a custom made 4WD 6s powered 1/5 on road, I call a Rev-Osi revo & losi drivetrain.
If I need to ditch the revo and losi diffs and axle shafts I am fine with that, so what do I need to go stronger ?
it looks like ofna or hot body gears in FLM bulks, is that correct, if so which ones ?
Please point me in he right direction
Thank you
http://www.rc-monster.com/forum/show...t=17074&page=6
thank you
Urgeoner
Urgeoner's Avatar
06.01.2010, 07:26 PM
http://www.rc-monster.com/forum/showthread.php?t=25614
