Best way to grind a flat spot on motor shaft
jamesban
Unhappy Best way to grind a flat spot on motor shaft - 06.01.2010, 11:50 AM
The flat spot on the shaft of my motor does not go back far enough on my motor. I did this a few years back on another motor and I attached locking pliers to the shaft and used a dremel tool but I didnt get it level so the pinion would slide forward when tightened down since it wasnt flat level. Is there any good trick to doing this? Thanks.
06.01.2010, 11:53 AM
I just use a dremel as well and eye ball it when done. You could always take a flat file as well to help smooth out imperfections. I have had no issues w/my pinions falling off. Just don't forget the blue lock-tite as well.
06.01.2010, 11:57 AM
Cover up the front bearing though... Poke it through a plastic bag and tape it up good...
nitrostarter
nitrostarter's Avatar
06.01.2010, 12:06 PM
As well as any holes in the motor can and endbells.
N. Rustler conversion
06.01.2010, 12:13 PM
Any your eye's ;)
06.01.2010, 01:41 PM
Any your eye's ;)
most imp't IMO
jamesban
06.01.2010, 01:52 PM
Im going to try to put the shaft ina vice with just a little bit of the flat part sticking up out of the top of the vice and use a file to try and get it straight this time.
06.01.2010, 04:02 PM
Be careful to not mark up the shaft to much in the vise...you will not get the pinion on if you do.
I wrapped my motor w/a cloth then put the whole motor CAREFULLY in the vise so the shaft was sticking completely out...then as stated above used a plastic bag to poke shaft through then ground flat spot
whitrzac
Can't catch this...
whitrzac's Avatar
06.01.2010, 04:30 PM
can you put the pinion on backwards?
Semi Pro
Semi Pro's Avatar
06.01.2010, 06:01 PM
or just dont use a set screw, red thread lock is your freind
06.01.2010, 06:55 PM
mini torch (heat) to remove them or what?
whitrzac
Can't catch this...
whitrzac's Avatar
06.01.2010, 10:36 PM
JAILBIRD
06.02.2010, 07:18 AM
One thing I do is place a strong magnet on the shaft opposite where you are grinding to catch the filings. That and the plastic bag should keep your front bearing nice and clean.
-JB
