guys..need some help w/the LB10A ballancer and what is needed
guys..need some help w/the LB10A ballancer and what is needed - 06.10.2010, 03:27 PM
Ok..I have a hyperion 1210i and am going to upgrade my equinox balancer to the LB10A balancer. So, what do I need to get w/it... I am a bit confused as there are so many leads adapters you can get.
I am using JST/Align taps
any help would be greatly appreciated
nitrostarter
nitrostarter's Avatar
06.10.2010, 03:44 PM
The LBA10 leads plug into the output of the charger. The the LBA10 had leads that you solder your Deans, TRX, EC5... plug on to. Next to these leads is a balance port where you plug in one of these:
http://www.rc-monster.com/proddetail...LB10XHB&cat=19
Then you should be good to go.
N. Rustler conversion
06.10.2010, 06:37 PM
Thanks!
06.10.2010, 04:09 PM
You also need a male to male servo lead so that you can see cell voltages on charger. All 610i balance leads work
