Revo 3.3 engine problem
Sanguary
Revo 3.3 engine problem - 06.19.2010, 08:38 AM
Got a revo 3.3 4 weeks ago, completed break in and then got retuned, but now i do 1/2 a tank of 25% nitro, and looses power and is hard to start, is generating heaps of blue smoke, so not too lean
Any ideas what it is?
Urgeoner
Urgeoner's Avatar
06.20.2010, 01:46 AM
Go brushless...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.20.2010, 02:38 AM
I'm no nitro mechanic by any means- but could it be getting too hot and causing a gap to form between the piston and sleeve due to expansion, which would lead to a partial loss of compression? That would cause the symptoms you are experiencing. I assume it starts fine once it sits for a while and cools down?
Oh yeah, a BL conversion would be a good idea, too!
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
06.20.2010, 09:16 AM
The problem is that it's a Traxxas engine, and it's not brushless! Really need more info to give you an idea. Will it start when it's cold or just hard to start when it's hot? It may be to rich if it has heaps of smoke coming from it. Glow plug could be bad.
Sanguary
06.20.2010, 09:59 AM
no its hard to start warm or cold, have changed glow plugs so many times i should get shares in company
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
06.20.2010, 12:31 PM
I go back to my original statement then! It's a Traxxas engine and thats what you can expect! That's the number 2 reason I went brushless, number 1 is that brushless is more powerful.
Most likely your mixture is off, go back to the original settings on the carb which I beleive is flush on the low speed and 4 - 4 1/2 turns out on the highe speed needle. Get it running and then tune it again.
mbx1275
06.21.2010, 07:16 AM
+1 more for bl cc2200 on 4 or 5 cells
Hyper 10sc mmm 2650
Ae rival mmm 2200
Ae rival 1717....work in progress
Losi micro sct/rally
Sanguary
06.21.2010, 07:42 AM
brushless is fine, but i'm a noisy bugger
Urgeoner
Urgeoner's Avatar
06.22.2010, 08:31 PM
Then go brushless, but stick a baseball card in the wheel spokes...should sound really loud and good.
TexasSP
Something, anything, nothing
TexasSP's Avatar
06.23.2010, 05:26 PM
You're on the wrong forum for nitro my man. Check out the traxxas forums, or rctech, or rcuniverse, or something more specific to nitro.
www.cubicle101.com
swiftneed
swiftneed's Avatar
06.23.2010, 06:26 PM
Yeah you should try the brushless instead of spending time to get it started while brushless is brushing right by you lolcheck your plugs and their breakin period is several tanks
  • RCM XT8 MMM NEU1521 1Y AKA TIRES HITEC 7955 TG 6S
  • MBX6T MMM CC 1518 HITEC 7955 BRAKE 5645 MG 6S LIPO
