Brushless EMaxx Spur gear question
studysession
Brushless EMaxx Spur gear question - 04.08.2006, 07:55 PM
What is everyone using after they strip their spur gear? My stripped on second run. I know the mesh was correct. This happens everytime I upgrade anything to brushless. I always have to either upgrade the differentials and stock spur gears to after market everything.
The Feigao 8L on 12 cells using the BK-Warrior 9918 Brushless ESC. Hads loads of power and very fun to run. Just stripped the spur.
http://studysession.com
Sponsored by:
http://www.mtroniks.net
http://www.brushless-motor.com
http://www.modelelectronicscorp.com
mmdooley
mmdooley's Avatar
04.08.2006, 08:37 PM
You need a strobe slipper. It's a 1/8 setup. Mike has what you need if the strobe's came in. They have been on backorder. You will need a ONFA 51 tooth spur and the strobe setup. It's easy to put on. Good luck.
WE DON'T STOP PLAYING WHEN WE GET OLD. WE GET OLD WHEN WE STOP PLAYING.
infinite_loop
04.08.2006, 08:52 PM
If you can't wait for the strobes to come in, the Robinson Racing Double Disc Slipper Kits are a decent alternative.
I'm currently running that on a 9918/9L combo and it's worked fine.
Either way, stick with plastic spur gears...
  Send a message via AIM to infinite_loop Send a message via MSN to infinite_loop
Sylvester
Sylvester's Avatar
04.08.2006, 08:54 PM
Ive been running on 14-16 cells on a 10l and my spur is still fine.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
studysession
04.08.2006, 08:55 PM
Thanks - I want to stick with the 32p gears.
Sponsored by:
Sylvester
Sylvester's Avatar
04.08.2006, 08:57 PM
Yeah, just try to tighten it as hard as you can, set the mesh perfectly, and if it still strips than you need mod1 .
Losi 8ight e
mmdooley
mmdooley's Avatar
04.08.2006, 09:02 PM
I agree with Sylvester the mod1's are the strongest for bl.
