Mind that puddle!
Gustav
Gustav's Avatar
Mind that puddle! - 04.11.2006, 10:42 AM
Had a total RC disaster yesterday.Been having some stabilty issues with my losi MF2,basically can't keep the front wheels on the ground since I under cut the middle 3 treads on the rear dirt hawgs by a few mm which makes little fingers to grip the tarmac,solved the traction problem but now it works a little too well.
i was doing a little speed run,feeding the power in then at around 40mph go for full throttle and it flips onto it's lid, then kept sliding for miles(bodyshells don't grip too good on tarmac) straight down the road,across the junction and came to rest upside down in a huge pool of muddy smelly silage crap.Took a pretty good dunking,when i picked it up all the water poured out of the body.Spent last night rebuilding the car,transmission was full of water.That's the second time my schulze has been for a swim and survived.Just let it dry then vacuumed out the silt and it still works!
Anyway,came up wth an ingenius high tech engineering solution,taped a load of coins to the front bumper,about 80grams worth and it works a treat.Now both ends rise up when i go full throttle but it cant quite lift the front fully,the front wheels kind of skim along the ground.Sorted.
ID:	1067   Click image for larger version
ID:	1068   Click image for larger version
bigabike
04.11.2006, 11:58 AM
Wow, that schulze is really durable! Glad it is still working!
Cheers
:030:
Gustav
Gustav's Avatar
04.11.2006, 12:06 PM
Yeah it's like a cat,7 lives to go.
I don't think water has ever actually got on the PCB itself since it's got splash protection sealant stuff.It was upside down,i think only the heatsink was under water,lucky.
boss 302
04.11.2006, 01:31 PM
shuzes dont like to stay alive when they stay dry but yours stays alive even through water. man your lucky.
maxxdude1234
maxxdude1234's Avatar
04.11.2006, 01:39 PM
Gustav, your the first person I know to have found a use for 2 pence coins! Nice Work!
Glad to hear your schulze didn't give up the ghost, bit lucky there I think
squeeforever
squeeforever's Avatar
04.11.2006, 01:54 PM
yea, my 9918 didnt like a few drops...but they warranted it for free...anyway, i would try some lead weights like for balancing car rims. i used 1/4 oz. im the front of my xxx and if jumped much better and more predictably. i would try them since there free (at least around here) and lead is much more dense than those coins probably.
Gustav
Gustav's Avatar
04.11.2006, 05:08 PM
I might go with pound coins for some more bling once i get it fine tuned.
Mike.L
Mike.L's Avatar
04.11.2006, 05:24 PM
your soo lucky man! last time i hit a puddle all my electronics fried. and out the window they went :)
  Send a message via MSN to Mike.L
Sylvester
Sylvester's Avatar
04.11.2006, 05:59 PM
Glad to hear everything was ok, man that shculze(sp?) can take a bit of a beating! Too bad they arent made for dry surfaces ;)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
