Castle Neu 1717 Bearings Size
andreazinno
Castle Neu 1717 Bearings Size - 10.26.2010, 04:12 AM
Hi all, I would like to change the bearings of my 1717 so to use hybrid ones (steel + ceramic) as I've done for the 1520.
Does anybody knows the size of such bearings ? I have the 1717 with a 5mm shaft, but I noticed that the shaft reduction from 6 to 5 is just for the outer part of the shaft, while the inner remains of 6 mm.
Thanks, Andrea.
Unsullied_Spy
Unsullied_Spy's Avatar
10.30.2010, 12:15 AM
http://www.bocabearings.com/bearing-...1717-1y-1580kv
andreazinno
10.30.2010, 02:21 AM
Originally Posted by Unsullied_Spy View Post
Mmh...still some doubts.
The bearings in the kit are 5x16x5 but the shaft of my 1717 seems to be of 6mm at the bearing level (the reduction from 6 to 5 is just in the outer part of the shaft)
Bye, Andrea.
Shonen
Shonen's Avatar
02.08.2011, 09:25 PM
Unless there are different versions of the 1717, the Boca bearing set is WRONG! my ceramics don't fit, they are 1mm too small diameter. I've emailed Castle to verify the bearing sizes but they haven't gotten back to me yet. I took out the front bearing and it's 6x17, forgot to measure the width but googling has returned 6mm. Want to make double sure with Castle before I send them back though.
Anyone can confirm?
andreazinno
02.09.2011, 02:08 AM
Anyone can confirm?
I got an email from Castle confirming that the inner diameter of the bearings is 6mm, so the right size should be:
- outer diameter: 16
- inner diameter: 6
- width: 5
Are You saying that the outer diameter on the bearings is instead 17 mm and the width is 6mm ? That surprising me, because when I sent the email to Castle I asked if the size was 16x6x5 and my question was specifically on the inner diameter (because of the shaft reduction fo the 1717 from 6 to 5). Castle replied me that the inner is 6 mm but says nothing about the other measures, so I assumed that they was as I've asked (16 outer and 5 width).
Bye, andrea.
Shonen
Shonen's Avatar
02.09.2011, 02:35 AM
^ I don't have time to tear down my E-Revo right now but I did take a photo while taking apart the 1717:
stock 1717 bearing
Boca 1717 bearing...
wish I grabbed the dimension of the width (thickness) of the bearing while I was at it, but I was just so frustrated at the time I didn't bother. :\
maneba
02.09.2011, 05:46 PM
Thanks, Andrea.
Ciao Andrea! Se li ordini li prendo pure io poi me li spedisci in prioritaria. Fammi sapere quanto ti devo.
Hi Andrea! If you buy the bearings from Boca i'll join you!
andreazinno
02.10.2011, 02:46 AM
Hi Maneba, just yesterday spoken with Gareth of Boca Bearings and he said to me that from today on the 1717 kit should be updated with the right bearing size.
Yes, probably I'm going to buy the kit....is this ok for You ?
Bye, Andrea.
Ciao Maneba, proprio ieri ho parlato con Gareth di Boca Bearing e mi ha detto che gią da oggi il kit dovrebbe essere aggiornato con le giuste misure.
Si, direi che dovrei prendermi un kit, pensavo a questo. Per te č ok ?
A presto.
maneba
02.10.2011, 12:10 PM
Perfect!
