Lipo Testing Advice
kulangflow
Never Fast Enough
kulangflow's Avatar
Lipo Testing Advice - 12.22.2010, 09:39 PM
Greetings!
I want to test my personal lipo collection. I have an Eagle Tree and a brushless set-up with an airplane propeller to provide the load.
I am seeking suggestions as to the strategy for testing my packs against each other.
For example, here is what I am thinking so far:
-Full batteries at room temp, approx 1 hour off the charger. ETree Temp probe taped to the battery.
1) 0-100% throttle and hold for 1 second.
2) Rest at 0% for 5 seconds, then repeat step 1.
3) Repeat 1 & 2 four times
4) 0-100%, and hold for 10 seconds
5) Rest at 0% for 5 seconds, then repeat step 4.
6) Repeat 4 & 5 four times
7) Hold throttle at 100% for 60 seconds
8) Rest at 0% for 60 seconds
9) Hold throttle at 50% for 60 seconds
10) Hold throttle at 25% for 5 minutes
If I did this for each pack, it should be a reasonable means for comparing them to each other I think. I'm not trying to compare brands to brands or anything, this is just for my own nerdy enjoyment.
Thoughts on how I could improve this?
Thanks!
Brian
snellemin
2 KiloWatt RACER
snellemin's Avatar
12.22.2010, 11:17 PM
I just discharge them at 35-40 amps and charge them right back up with zero cooldown. I check the battery temp during discharge. The pack actually cools down when charging. I do one more cycle, but this time charge them at 20A and check the resistance of each cell. Now the pack is ready for the test.
The rest I would do the same as what you have described.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
kulangflow
Never Fast Enough
kulangflow's Avatar
12.24.2010, 01:05 PM
Thanks for your response!
I did some testing last night, and it was pretty cool to see the results.
This comparison wasn't meant to show brand vs brand. All these packs are used and abused. I was just curious to see how they compared. Although the result is obvious, it's cool to see on a graph how much better the 1600 packs do in parallel than by themselves.
I did 3 full throttles for 10sec, with 10sec rest between. Then I did a 50% throttle run for 60sec, and ended with another 10sec full throttle burst. I let them recover for 45sec, then ended live mode.
snellemin
2 KiloWatt RACER
snellemin's Avatar
12.24.2010, 01:28 PM
Nice to know what your batteries are capable off heh!
