Question about 2200KV on Ext. Savage for Castle Staff
togepipro
Question about 2200KV on Ext. Savage for Castle Staff - 01.20.2011, 09:38 AM
This is my current setup, I test it last night in front of my home, and I notice that sometimes at start the truck move pretty slow, no matter I press the full throttle. But when is moving normally if I press the throttle a little more It does the Satan wheelie. I don't have enough amps on the batts for this setup? I solder two 35V big capacitors a time ago on the MMM. This is my first time with lipos.
The truck is two year old, the wheelbase is 17". I only change the bearings once.
Differential Ratio: 3.2222222222222223
Transmission Ratio: 2.215277777777778
Other Ratio: 1
Spur Tooth Count: 44
Pinion Tooth Count: 18
Total Voltage: 22.20 6s Lipo 40-50C (Cheap ones) 5000mAh They are new.
Motor KV: 2200
Tire Diameter (inches): 6.69
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.006
Spur/Pinion Ratio: 2.44 : 1
Total Ratio: 17.44873 : 1
Tire Circumference (inches): 21.02 inches (533.84 mm)
Rollout: 1.20:1
Total Motor Speed: 48840 RPM
Vehicle Speed: 55.71 mph (89.49 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
I'm going to test tonight with the 52T spur = 47.14 mph. To see what happens.
A pic of the truck
DrKnow65
DrKnow65's Avatar
01.20.2011, 10:29 AM
6S 40/50C, but what is the mah capacity? Example, 3000mah 5000mah...
If it pulls wheelies I would say you have sufficient power, maybe it's a setting?
What is the "start-up" power set to?
togepipro
01.20.2011, 10:37 AM
Sorry forget to add that, the capacity is 5000mAh, the setting is on "Punch-Control" power is on 100% (for low traction). I change it to 0% for the test today. Remember the truck start normally sometimes.
DrKnow65
DrKnow65's Avatar
01.20.2011, 10:43 AM
Yah, test it with a little more start power :-)
P.s. I noticed you had "for Castle Staff" in your title, I'm not castle staff, but I'll help if I can :-)
togepipro
01.20.2011, 11:54 AM
Ohhh don't worry any help is great =) Lets see if I can take a video of the truck to show what it does.
Thanks DrKnow65
nuz69
nuz69's Avatar
01.20.2011, 12:15 PM
Maybe a bad firmware, try the 1.24 version for see ?
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
togepipro
01.20.2011, 12:30 PM
I'm using the 1.30, if the problem persist I'm going to change it to see.
A friend have a Kyosho GT2 with a 2200KV system (72MPH single speed) and start behave weird after a update so we roll back it to 1.21 and work great.
togepipro
01.20.2011, 08:37 PM
Was the firmware! Why I dont test it first!!! Before disamble the truck to change the gears lol.
Well 1.30 dont work for me, 1.21 runs great.
So I should apply something that I apply at work "If something work great dont upgrade it, unless is Microsoft software or the Antivirus"
01.20.2011, 08:46 PM
I didn't like 1.30 either. It starts moving, then "kicks in". Went down to the last non-beta release.
DrKnow65
DrKnow65's Avatar
01.20.2011, 09:24 PM
I dunno, kind of torn on the upgrading microsoft part.
I do upgrade my windows 7 professional 64bit pc's here at home,
but I have one that I kept XP on, and NEVER let it do ONE update.
It lasted years and years and never had a crash (Dell 8300) and is now running W7 32bit happily...
togepipro
01.20.2011, 10:07 PM
The XP 32bit was very stable after the SP1, the 64bit was a joke...
Vista work great after the updates but still pretty slow. (Never install on my labs, thank god)
Windows 7 64/32 version are pretty great.
DrKnow65
DrKnow65's Avatar
01.20.2011, 10:42 PM
7 x64 pro has been as sweet as I had hoped every other windows would be.
P.s. sorry for the hijack
