9L vs 10L vs 7XL (14 cells)
infinite_loop
9L vs 10L vs 7XL (14 cells) - 04.28.2006, 04:42 AM
Just curious..what kind of speed difference would I be looking at if I changed from a 9L to a 10L or 7XL on 14 cells?
I love the speed of the 9L, but it runs a little on the hotter side. Would either of the other two lower temps? Would I be able to gear up on either one to get the same speeds as I get with the 9L (16-18/70)?
And finally..if I went with the 7XL, would it be too much for the following upgrades I already run:
-MIP rear CVDs/RCBest Front and Center CVDs
-Single Speed Tranny w/UE Idler
-NovaRC (Front)/FLM (Rear) Aluminum Diff cups with stock spider gears (Rear also has Modified Robinson Ring/Pinion)
Everyone raves about the XL series..but if I can't get 9L-like speeds or if I have to upgrade to the pricier UE cvds and spyders..then I'd rather not...
Sorry for all the questions! Kinda new with brushless and although I've learned a lot, there's still LOTS MORE to know! :018:
  Send a message via AIM to infinite_loop Send a message via MSN to infinite_loop
Nick
COOKIES!
Nick's Avatar
04.28.2006, 05:53 AM
7XL and 10L will be slower than the 9L unless you gear up.
I reccomend the 7XL, I run it on 14 and it is a hoot. Quick and powerful and won't get hot. You'll be fine with that setup on a 7XL.
~ Nick.
coolhandcountry
coolhandcountry's Avatar
04.28.2006, 07:14 AM
The 7xl gets my vote to. Your driveline should be fine with the mods you have for 14cells. You may want to get a bigger pinion though. 20 66 should be a good starting point.
Peace!
Country
Help support the
Rc-Monster
Buy here
Sylvester
Sylvester's Avatar
04.28.2006, 10:16 AM
I ran my 10l on 14 cells, was alot of power, didnt get too hot, enough to keep my finger on it, but id say 7xl, it should be even better.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
infinite_loop
04.28.2006, 12:41 PM
speed wise..how big/small of a difference am i looking at with a 9L (16/70) and a 7XL at 20/66 (~21/70) as CHC recommended?
cart213
cart213's Avatar
04.28.2006, 01:17 PM
My calculations suggest about a 10 mph increase in speed. I've never used a 7XL, though, so I'm not sure how they run in the real world.
Electric Dave
04.28.2006, 04:26 PM
I've run a 9L and 10L on 14 cells, both were close in terms of speed (with gearing changes) and they both are way too hot for my liking. I run about 7 mins in practice and they are VERY hot (180-210). For the races, I only need 5 mins so they are usually 170-200, I let them cool then run again. When my 10L dies, I'm getting an XL or one of the Lehner 1950's.
infinite_loop
04.28.2006, 05:03 PM
Yeah..that's why I'm think the 7XL. Just curious about the speed differences with a 9L on 16/70 gearing compared to a 7XL on like a 20ish/70 gearing
Electric Dave
04.28.2006, 05:04 PM
My take, you can compensate for the lower kv with gearing. Do the 7XL, then let us know how it is.
infinite_loop
04.29.2006, 02:41 AM
BTW..what's the runtimes like on a 7XL w/14 cells?
Serum
Serum's Avatar
04.29.2006, 06:19 AM
about 15 minutes, depending on your drivestyle.
the 7XL or 10L gets my vote too.
infinite_loop
04.29.2006, 06:24 AM
Yeah..I'm leaning towards either the 7XL and 10L, too.
Hey Serum..how much of a speed difference would there be from those two as opposed to the 9L? Or would I be able to get same/higher speeds after gearing up?
And does the 10L run cool enough compared to the 9L that I should consider it?
Big Daddy
04.29.2006, 08:59 AM
I use a 10l in my savage, and depending on how I drive it depends on how hot it will get. Most days it does not get too hot. It will get warm but nothing blistering. I will be using 16 cells on it soon to see what kind of difference there is and maybe going to a 9 or 10xl
Sylvester
Sylvester's Avatar
04.29.2006, 09:07 AM
I run a 10L on my g2r, i run it on 16 ib4200's, i am getting a 10xl, this is so because i am loosing runtime due to the motor getting hot, but on 14 cells the 10L ran fine, no problems what so ever.
Losi 8ight e
infinite_loop
04.29.2006, 09:13 AM
Sylvester: what types of runtime were you getting with the 10L on 14 cells?
Assuming I will only run on 14 cells, should I just upgrade from a 9L to a 10L than a 7XL?
Still curious about the speeds, too. On correct gearing for each, what kind of speed differences am I looking at between a 9L, 10L, and 7XL?
