MMM vs MGM 16018, resistance
Candyman2
Candyman2's Avatar
MMM vs MGM 16018, resistance - 04.21.2011, 03:28 PM
So I have an mgm 16018 on 6s, would I notice a difference if I switched to a mamba monster max? is the mmm any more effecient that I would notice more top end say?
Sounds like
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Sounds like - 04.21.2011, 03:57 PM
Well you said it. Sounds like a good reason for a comparison test with eagletree data for everyone to see. While your at it why not use a MA True 150C rated Lipo and compare it to lets say an equal Turnigy Lipo pack. Then you would be able to kill two birds with one stone, right? It would be interesting to see a direct comparison with these two products. Please share your experience with us.
SUPERMAXX YOUR LIFE.
Candyman2
Candyman2's Avatar
04.21.2011, 04:30 PM
wo wo wo there!
lol :)
Theres me trying to get out of de-soldering the Mamba from the crt, guess i'll have to do it myself then! :D no eagle tree here im afraid, you'll have to do with "yeh its a bit quicker" or "na its the same"
Dj_Sparky
04.21.2011, 06:44 PM
Lots of people claim Max Amps batteries are poor, even compared to Turnigy. Based on the MA price and the fact they are still in business, I'd have to say I find that hard to believe. But, I haven't tried any MA batteries.
crazyjr
crazyjr's Avatar
04.21.2011, 06:58 PM
I'm not sure if its faster, But i bet it is more efficient. I run one (16018) with an over-geared lehner 2250/10T in a twin force, on 6s lipo. never once got hot at any time in the run.
On a side note, is there a american distributor for MGM?
Dj_Sparky
04.21.2011, 07:14 PM
How does the Twin Force handle that power? I tried once with 3s and the torque made it pretty much undrivable. Have you modded it or something?
crazyjr
crazyjr's Avatar
04.22.2011, 05:00 AM
It was mostly onroad i drove it, due to lack of parts, this was before the re-introduction. This particular truck was bought off Ebay from Promod, Most old school MT guys will know that name. This one has a New era Long wheelbase chassis and a center diff with buggy diffs, seemed to handle the power nicely, but never pushed it. I broke the right rear housing at the knuckle and plan to get it running again. Even with a leaking diff it would slam the wheelie bar hard and run close to 45 easily.
Back to the 16018 though, I was using a eagletree 100 amp micro data logger,and logged a few 120+amp runs with around 2600watt peaks and the MGM never broke a sweat. The gearing was buggy diffs with a ofna diff (I think) a 51 tooth plastic gear, the one used by most strobe slipper setups. I was using a 19tooth Monster pinion on the motor. here is a BrianG setup showing the setup
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 19
Total Voltage: 22.20
Motor KV: 1183
Tire Diameter (inches): 5.6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.68 : 1
Total Ratio: 8.87854 : 1
Tire Circumference (inches): 17.59 inches (446.86 mm)
Rollout: 1.98:1
Total Motor Speed: 26262.6 RPM
Vehicle Speed: 49.28 mph (79.16 km/h)
Effective KV Value: 1183
KT constant: 1.14 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
As you can see it was massively over geared and the MGM never broke a sweat, Most runs were around 5-10 minutes. I wouldn't mind running the MGM's again but the expense and the lack of U.S support make it almost not an option
Mgm compl pro.
JERRY2KONE
JERRY2KONE's Avatar
Mgm compl pro. - 04.22.2011, 05:12 AM
I have a couple of MGM ESC's myself, but have not run them because of the customer support issues. I started a thread last month about the fact that I am living in Prague now and will be here for the next few years, so I am planning to pay a visit to the MGM shop in Zlin, Czech Republic once our van arrives and we can take a drive out there. I have exchanged emails with one of the owners (Martin) and we are looking forward to discussing the matter to see if this can be resolved. His view on the matter at this point is that they are already doing everything they can from a foreign location perspective, but he is willing to hear complaints and if there is a better solution he is all ears. Our van should be here in the next few weeks, and then we can make plans for the trip. From what I am able to assess on our TomTom GPS this will be a 5 hour drive just to get there so the wife and I will plan an overnight stay and hopefully I will get to spend some time at the MGM shop.
Hey just noticed that there is a "Spell-check" program operating on here now. Way yo go Mike.
BIG-block
04.22.2011, 10:23 AM
I don't own amy MGM ESCs but would love to try some in the future although that comment doesn't sit well with me. "Doing all they can from a foreign location perspective". Castle is in US and I am in Australia. Never had an issue dealing with them. Something was faulty and within 12mth warranty period they would sent me out a replacment free of charge as soon as they receive the faulty item. If MGM aren't doing that then I doubt that they are doing all they can. I know that those are their words Jerry so not having a go at anything you said. Just pointing out that they might not be doing all they can.
Unless?
JERRY2KONE
JERRY2KONE's Avatar
Unless? - 04.22.2011, 01:38 AM
Unless something has changed MonsterMike did have them in the RCM store.
