mmp leds blinking
dracbec
mmp leds blinking - 04.29.2011, 05:10 PM
all the leds on my mmp are blinking and its brand new and i cant calibrate or anything....i already updated the software and turned off the lvc just in case it was something like that.....oh and the fan runs all the time?
anyideas asto what could be wrong?
04.29.2011, 07:50 PM
http://www.rc-monster.com/forum/showthread.php?t=20020
Flashing all colors = speed control is not receiving a valid signal from the receiver, usually indicates the receiver wire is plugged in backwards into the receiver; possible problem with controller or with throttle channel on receiver.
Check your rx plugs & leads, and the transmitter batts.
dracbec
04.29.2011, 08:37 PM
i have done all of that even a hole diffrent radio system
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.29.2011, 11:58 PM
Don't take it the wrong way but is it plugged into the rx correctly? I have accidentally plugged my esc into the rx backwards before and iirc that is exactly what mine did. Make sure the tan wire is in the - position, usually to the outside of the rx
dracbec
04.30.2011, 12:05 AM
yep checked that and even turned it around to make sure
04.30.2011, 01:35 PM
Hmm, check the throttle trim & epa settings maybe- you might also need to try reversing the throttle channel.
