An Old project never completed to be done G4
swiftneed
swiftneed's Avatar
An Old project never completed to be done G4 - 05.16.2011, 07:05 PM
OK I have been in and out and got involved in other projects but I know I can get some help here I have a g4 with several other parts that, i have even bought other trucks to complete but the 3905 emaxx i dont want to take apart ok maybe later but I have gears I purchased for the project. WHERE THE HECK DO I START
ID:	9957   Click image for larger version
ID:	9959   Click image for larger version
  • RCM XT8 MMM NEU1521 1Y AKA TIRES HITEC 7955 TG 6S
  • MBX6T MMM CC 1518 HITEC 7955 BRAKE 5645 MG 6S LIPO
swiftneed
swiftneed's Avatar
05.16.2011, 07:15 PM
THIS IS THE OTHER TRUCK EMAXX ALSO
By swiftneed at 2011-05-16
05.17.2011, 11:39 AM
Okay, so what you have there is an old 3906 transmission and some metal ( aluminium maybe- are they magnetic?, heavy or light feeling for their size? ) output gears- those are no good for your G4 truck.
You need to hit up ebay for a complete Emaxx 3903/05/08 transmission and motor mount + slipper clutch ( though the slipper can be upgraded easily enough if you need to, there are a couple good options about ).
You can always stick the 3906 tranny back in the old emaxx and run that as it is or let friends drive it etc, to spare your nice truck from their bad driving
05.18.2011, 06:25 AM
Are those all of the parts you have?
Is your goal 1 or 2 trucks?
I believe you need gorillamaxx specific skid plates, which I didn't see. (Neil would know)
swiftneed
swiftneed's Avatar
05.18.2011, 06:33 PM
iT SEEMS i AM GOING TO POUR MONEY INTO ANOTHER EMAXX FOR PARTS WHEW THE ADDICTION TO BROWSIN
B-Money
05.19.2011, 03:12 AM
in my G4 i have used stock skid plate. They are ok but some titanium ones would be better, cause the whole front portion can move when only attached at the bulkheads.
I have the plastic ones on mine though and have never had any issues.
swiftneed
swiftneed's Avatar
05.19.2011, 04:28 PM
Am wondering if those new black rpm would work
05.19.2011, 05:55 PM
The RPM wear plates are not designed to replace the skids, they go over the top of whatever skids you use- stock is fine since the G4 doesn't use special length skids front or rear, just regular ones ( the old G2/3 extended version chassis used a longer rear skid and rear upper chassis plate ).
swiftneed
swiftneed's Avatar
05.20.2011, 07:29 PM
oh I didnt even know that it went over it what a newbie I AM thANKS NEIL
swiftneed
swiftneed's Avatar
05.20.2011, 07:32 PM
ok i ENDED UP BUYING ANOTHER EMAXX FOR TEARING DOWN AND ALSO PURCHASED A FASTLANE MACHINE 3905 TO MAYBE USE THE OLD TRANSMISSION WITH THE GEARS MIGHT INVOLVE SOME CUTTING BUT WILL INCLUDE PICS WHEN IT ARRIVES
05.21.2011, 12:09 PM
What model emaxx did you buy for tearing down?
You should be able to fit the 3906 tranny to the 3905 chassis buy widening the motor mounting area/ hole and drill new mounting holes- only really need 4 for the old tranny rather than 8, just enlarge the hole so the tranny fits, then mark the locations for the mounting screws & drill them with a 4mm drill bit.
swiftneed
swiftneed's Avatar
05.22.2011, 12:39 PM
I bought another 3905 and burnt the esc didnt realize after connecting I had connect the correct leads to the battery to the esc to program it I didnt i just connected and turned it on to try and program the remote to after several attempts and haveing the novak smart cutoff connected 2s it just blew but I think something may have been wrong with it
ID:	9968   Click image for larger version
ID:	9969   Click image for larger version
05.23.2011, 11:37 AM
That didnt make any sense at all sorry ( punctuation & grammar , you can't really connect anything up wrong unless you were trying to rewire the battery connectors ( there are only 2 plugs, a battery plugs into each one = simples ). The motors are easy to hook up, red and black wire goes to each motor & it doesnt matter which as they are wired in parallel. The only thing you could hook up wrong is the rx lead from the esc which has to be inserted the right wya around otherwise the esc just doesnt work ( no signal ).
Sounds like the smartstop was wired up wrong and shorted / the esc out...
swiftneed
swiftneed's Avatar
05.23.2011, 02:40 PM
well I think thats what i did with the evx wired it the wrong way into the lipo protecter thats ok cant wait to get the flm chassis
05.24.2011, 09:55 AM
Well, there are instructions for wiring them up on my website, always has been for years & the link is in my sig:
http://www.robotwars.00server.com/tutorials.html
Section 3 on LVCs is what you want, with various options for 2s & 4s LVCs and better options than the smartstop too...
