Lehner 1920
Tom F
RC-Monster on a Budget
Lehner 1920 - 05.02.2006, 07:51 PM
I'm on a quest for stupid ammounts of power - and i think a 19 series is the answer lol
Having had a lengthy (and very helpful) email discussion with Mike about the 1930, i think a 1920 is the way to go.
It's for something light weight, off road and 10th scale (a T3 or a 4wd buggy).
Couple of questions;
- Can you get them in stock?
- How much are they?
- Are they available with a 1/8" shaft?
- What winds are available?
I'm thinking of a 1920/8 (3919kV) on 3S, or depending on the price difference/availability, a 1930/7 (2986kV), also on 3S Lipo (and gear high, for the sake of my drivetrain).
Would these be suitable for this application? I have an MGM 120A speed controller planned for this, so that shouldn't be a problem - but what kind of current draw will i be looking at with these motors (so i can price up Lipo packs)? Would it be more worthwhile to just run something like 12 cells (although that would be heavy)
I would run a Feigao L series but a) it wont fit and b) i want something truly off the scale.
Recommendations? I've done a fair bit of research and i think these are the ones that would best suit my application. I'm going to be racing so i want power on demand whenever i need it, but it needs to be controllable too.
Thanks
- Tom
http://img513.imageshack.us/img513/3880/dscn1559dp5.jpg
Brushless - How fast do you wanna go today?
  Send a message via MSN to Tom F
Gustav
Gustav's Avatar
05.02.2006, 08:26 PM
You definately don't need the 1930 or a L can in a little 1/10th car. I GPS tested my xxxt on 4s with the 1920/10 for the first time yesterday,it recorded 57.1 mph on the first run and had alot more to give if it had more space.On the next run a tree destroyed the front end of the car but that's another story.
The 8 or 9 turn would be the logical choice on 3s but the 10 turn is very nice to run on 3s too(35K rpm),40 to 45 mph performance quite easily,milder and more controllable than my basic 4200 on 3s.Also the 10 turn runs very cool with long runtimes on 3s and has the ability to hit some big numbers on 4s.My Lipos are 66 amps continuous and they get warm enough to work properly,even in winter in the UK,but they don't get hot,they work very well at this kind of current draw.
Edit:P.S,you won't believe how much smoother and quieter it is than a lehner basic.
Tom F
05.02.2006, 08:30 PM
Hmmm...that sounds fantastic - only thing is, is that 4S LiPo is too expensive for me lol
What packs are you using?
I was planning on running 2S for day to day driving to go easy on everything, but 3s for madness
Edit: and what pinions/spurs are you using? i haven't seen 4mm bore 48 pitch?
Gustav
Gustav's Avatar
05.02.2006, 08:53 PM
It's harder to get a motor that runs good on 2s and 3s than on 3s and 4s because you have a 3rd difference in rpm instead of a quarter.The 1920/7 might be the ticket though,(33k rpm on 2s,and around 50K rpm 3s).That's what Thunderbruiser has chosen to do,i think he has 2s packs already but wants to run 3s aswell.That should do nicely on the track on 2s,it'll run very long runtimes and should run cool,I don't think it'll be blisteringly quick though but probably as much as you can laydown on the track.On 3s it will scream,might get a little hot but should be good for the occasional speed run/bash session,you might have to let it cool every 5 mins or so on 3s though.
Why not use your 5300 on 2s and get a motor specifically for 3s?The 5300 can probably get the best out of a 2s pack anyway.
I'm using the Flightpower evo20 3300 lipos,they're well priced and in the UK.
I have a lathe so i just run a 4mm drill through the 3.17mm(1/8") standard 48p pinions.You need to bore them out on a lathe for them to run true,if you're stuck and don't know anyone else with a lathe then i can help you out,just PM me and you can post me the pinions you want to use(alu. or non-hardened steel would be easier 'till i get my carbide drill bits).4mm is the way to go.
Edit;funnily enough we had almost this exact same discussion earlier todayhttp://www.rc-monster.com/forum/showthread.php?t=3029
Tom F
05.03.2006, 07:45 AM
That sounds great...i'm trying to get a powerful motor to run on 2 and 3S because otherwise i have to buy 2, 3, and 4 cell packs (as the 5300 and 6S are to hot to run regularly on 3s, i feel)
I hear what you're saying about the difference though...i like the sound of the 1920/7 - but i'm wary of running a motor with very few turns as i would like some reasonable degree of runtime, lol
What sort of runtimes are you seeing with your set up?
I'm going to email Lehner and ask if they can give me some ballpark figures on the current draw.
I still somewhat favour the 1930 - even though it will be a bit more expensive, it's available in a wider range of winds - however it will be heavy and current thirsty, not to mention the mess it'll make of my diff...gah i don't know
02.02.2009, 05:34 PM
Originally Posted by Tom F View Post
...I hear what you're saying about the difference though...i like the sound of the 1920/7 - but i'm wary of running a motor with very few turns as i would like some reasonable degree of runtime, lol...
For a given speed, the runtime between a low turn motor (high kv) geared low is VERY close to that of a higher turn motor (lower kv) geared up. The same amount of work is being done so power requirements are about the same.
If I were you, I would choose the motor kv to get around 35k rpm on 2s (4700kv) for the application you see yourself using the most. Then, gear it for the speed you want. For the times you want to "go crazy", you can still run 3s on that motor and still be well within the max rpm specs (52k).
So, if you plan to do more racing and have your 4700kv motor geared for 35mph (typical racing speed), hooking that same motor to 3s with the same gearing will get you right around 50mph give or take.
christianmoche
02.02.2009, 05:15 PM
any updates on this?
Tom F
02.02.2009, 05:30 PM
Wow, haven't been here in a while lol
Nothing that interesting in the end - I'm too cheap. Mamba Max 4600 with a 3S Kokam 4800 20C pack. It's pretty quick :)
mohanjude
Need for speed
mohanjude's Avatar
02.02.2009, 05:39 PM
I live in the UK and have purchased a large collection of Lehner motors over the years. I am still amazed on the power my Lehner 1930 demonstrates in my emaxx. Having been drugged on the Brushless power I purchased Lehner 1940, 1950, 2240, 2280 motors. The larger 22xx motors are for 1:5 scale conversions. I will still maintain that the grin I had on my face with my first brushless motor 1930/7 has never appeared with some of the subsequent motors such as bigger Lehners, Neu motors. The only other motor that came close to me amaze me in real life performance is a Plettenberg Big Maxximum which blew another emaxx conversion to destruction!!
