Brushless Boat Question -
03.28.2012, 04:32 PM
I'm looking into getting a brushless boat.
I've never owned or even driven a boat before. What would be a good boat platform to start with? There are many options out there and I just don't want to buy some junk my first time out.
I've owned a few brushless trucks and I don't mind working on the boat of doing mods to it.
I'd like to spend $300-400 for the majority of the parts needed for the boat. I have a Spektrem Tx/Rx that I think should work.
Thanks for the help,
Nick
03.28.2012, 05:17 PM
You want to try one RTR with a castle esc/medusa/spectrum?
I have one for sale
03.28.2012, 06:41 PM
RC-Monster RC8T
03.30.2012, 12:00 AM
I have a Spartan and it's decent but I wish I did more research and started with a Miss Geico
03.30.2012, 08:06 AM
I started to look at the Spartan, but then found the Proboat and AquaCraft were more recommended by veteran boat people.
Right now I'm looking at the Proboat Impulse 31 or the AquaCraft Motley Crew. Both around the $320-350 range.
These were the most recommended boats from the people over at Off Shore Electrics.
Nick
03.30.2012, 01:05 PM
Sounds like good advice if you dont like building and want a RTR boat, if you may want to upgrade it later go for the impulse, which will handle a full on P mono or P offshore race setup, whereas the AQ MC will fall apart if upgraded to much faster than stock.
That is not to say that they are not both race worthy boats, impulse will run P Spec mono or P Spec offshore classes as it comes, and the MC will run P Spec offshore as it comes.
What do you want out of a boat, how will you run it, in what conditions will you run it, on what size lake, how important are aesthetics to you? these are all questions that you should think about to decide what type of boat you want. Outriggers are the fastest, depending on sponson design can handle rough water well, are second best turning to the right, but dont turn left at all, are ugly and use up a lot of lake. scale hydroplanes are the second fastest, and are beautifull but dont turn right all that well, dont turn left at all, are the worst in rough water or high winds and take up the most amount of room on a lake. Cats are middling in the speed range and do well in rough water but not so great in the wind, there are 2 types, wide ones like the AQ MC that turn both ways very well and narrow ones like the Genesis that dont turn that well either way but are faster and better in the rough/wind. Monos are the slowest of the surface drive boats but are the best in very rough water as they can be made to self-right, like narrow cats they offer middle of the road turning in both directions. Submerged drive boats like ECOs are the slowest, but make up for it with huge acceleration, by turning in both directions jaw droppingly well, and are ideal for those with small lakes to play on, however if you are in the USofA and want to race I dont believe there is any ECO racing going on at the moment, so check with your local club. (in fact thats good advice for any of them, if you want to race or feel like you possibly may do in the future, do to your local club and see what others are running, to avoid building an amazing P Spec offshore for example, then finding that class isn't raced in your area.)
Size matters too a 16" Mini boat can be a lot of fun on a small budget, if you put that same budget into a bigger boat it would be pretty slow and boring, but if you have a bigger budget a bigger boat will handle any given wave conditions better and as always be more impressive
Once you have decided what size of what sort of boat you want then think about your build skills RTRs are easy and normally fairly cheap as it will all be Chinese gear assembled in China, but the quality of the gear and the build will not be the best as they are made to a price point, if you go with a RTR at least gge a good pull on the motor/servo/battery mount to make sure they are glued in solidly and make sure the driveshaft is lined up with the motor coupling, as these are often points of RTR failure, oh check all the screws too. If you are capable and willing to put your own labour into it you will probably end up with a better boat in the end but you may also be surprised to find that it costs you just as much or more if you don't use all Chinese components, which is the savings of bulk buying covering the Chinese labour cost, but you will undoubtedly put more care and attention into the build that a Chinaman with a quota of 20 boats to build today. RTRs also limit your choice severely as there are only a few good ones out there of all the types put together. Riggers, Tenshock Y and Mini Y. Hydros, AQ UL1. Cats, Toysport Jolly, AQ MC, PB miss Geico, PB Mystic, Astec Apperition. Monos, PB impulse 31, Toysport synchron, Toysport triton, Tenshock Mono1, Kintec rocket, Kintec persuit Joysway offshore warrior. Submerged drive, Tenshock Eco, Toysport Joker, Tenshock Mini ECO.
which is a pretty comprehensive list of all the RTRs that I think are worth a damn, and you wont find a tenshock or toysport in your LHS, tenshocks are only available in the USofA through minicatracing, and toysport arent so much an RTR as a smallscale hull company, but Joseph is happy to fit out his hulls to whatever stage the customer wants so are available RTR though neither hull hardware nor labour is chinese so as ever the quality comes at a price. If you are willing to build in wood from a kit or plans, or just fit out an empty glass hull the choice of top quality boats becomes much larger and there are numerous good hulls for each type in many different sizes.
Which Spektrum is it that you have? The early Spektrum steering wheel radios didn't work well for boats, if you have a DSM2 5+ channel aeroplane set it will be fine as is, or if it is a steering wheel set with a picture of a boat on it will be OK if you get a MR3000 or MR200 reciever to go with it. If its a steering wheel set without a picture of a boat on it, it's low power DSM1 s#!t and not worth losing your boat over.
Check out the website in my signature, lots more info there than I can put in a post.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
03.30.2012, 01:46 PM
Wow that is a lot of info right there. Thank you very much for taking the time to explain all of this to me.
I will be using this boat as a test to see if I really like driving/ owning a boat in general. I will be using it on a good size lake in ME along with other small bodies of water around where I live.
I'm not looking to race at all or join a boat club.
I have a newer Spektem DX3S but I would need a Marine receiver.
I think I would be running on mostly calm waters most of the time. The lake in ME is pretty quiet just small boats and anywhere else wouldn't have any boats in it.
If I do get a boat I will be going out with a buddy of mine who does a good amount of fishing on local ponds around the area, once he sees mine he will probably want one as well.
I think for my first boat I'd like to stay with a RTR boat, then if I do like it a lot then I'll build my own.
Thanks again for the help,
Nick
03.30.2012, 01:16 PM
I also have been pondering a boat for yrs seeing as I am surrounded by ponds and salt water. Just never got the bug I guess. Although with the summer fast approaching, I am thinking of one again.
03.30.2012, 03:52 PM
For a RTR to do general boating about in a mix of large and small lakes with calm water I would probably go for the AQ Motley crew, but some may say I'm biased towards cats, while I've had all the types of boats, most have been cats.
When you become blase with the speed don't stick a bigger motor in it, build yourself a 4s rigger with a 1515 in it and make your mate's jaw hit the floor. Again!
Lots of boats.
fastelectrics.net
03.30.2012, 10:28 PM
Once again, thank you very much for the information and help.
Why do you prefer a cat over a regular v hull?
Can you show me some pictures, video and build threads on a 4s rigger with a 1515? Also, what am I looking at price wise to build something like that?
Nick
hydro -
03.31.2012, 03:16 AM
Nick
http://youtu.be/E1pF2oDETYk
03.31.2012, 01:05 AM
Keep in mind, the run times on a boat will not be the runtimes you get in your land vehicles. Boats are normally run wide open throttle for the majority of a run which eats up mah.
RC-Monster RC8T
03.31.2012, 12:27 PM
Very true, 5s 5000mah lasted me about 17 minutes in my RC8T, 5 minutes in my Spartan. I bought a set of Traxxas 10,000mah packs and I get about 9:30 out of them.
03.31.2012, 12:30 PM
I prefer the speed and handling of cats and like to live life on the edge so a little less stability in the wind doesn't bother me. If it is an issue to you get the Tenshock Mono1 as it is the only self-righting RTR close to your budget.
Plenty of info on the boat mini_t racer linked in this thread on RRR & OSE
I built the boat above and it cost me:-
$100 for the kit
$130 hardware.
$199 1412/1y is the motor I wanted but Nue wont let you order direct and it was taking castle so long the Emailed me asking if I wanted to cancel and I had a line on a used 1415/1.5D so ended up paying $120 for that motor.
all the rest of it was bought here in the UK or used from my stores so aproximate dollar prices for new replacements from here on.
$45 Skywing 200A ESC
$15 thermal epoxy to watercool the above air ESC
$5 alloy tube to watercool the above air ESC.
$5 electronic grade silicone sealant to waterproof the above ESC, RX and Servo.
£100-200 4s battery pack, last 2 seasons I went for the cheap end, this year I will be getting an expensive TP pack.
$60 servo.
$10 6mm bullets.
$5 bottle of medium cyno.
$15 30 min epoxy.
$30 epoxy laminating resin to seal the wood.
$40 paint, paint is optional as the laminating resin makes it waterproof and the natural wood does look pretty good, I used primer 2 colours and clear which all adds up.
$10 stanley/craft knife.
$10 emery paper.
$5 grease for cable.
$5 oil for motor bearings.
$200 Futaba 6EX radio/$65 for RX/free as I had it already, depending on your viewpoint.
Prop, sky is the limit here $7 for graupner carbon props that dont need balancing, 10-20 for BeCu or stainless metal props if you can sharpen and balance them yourself, $20 for a good magnetic balancer, $30-70 if you need someone else to do it for you, or $1000+ for a box full of props built up over the years like I have.
The one on the right hand side is my 1415 rigger.
I may as well answer you PM here so all can see, i favor the AQ MC to the PB Impulse Purely de to my own bias towards cats and personal preference, there is nothing wrong with either for the stock power, it is just like me prefering buggies to monster trucks, and F1 to Nascar.
The PB impulse and AQ MC both have very similar power systems and as such will give similar run times, as nitrostarter said dont expect anything like the run time of your cars/trucks though, if i pull ovals with my onroad buggy i get peaks of 120A but the average ampdraw is only 20A my boats which are set up for Naviga hydro racing I pull an average of 70A with peaks of 120A 15 min runs with the buggy and 5 minute runs with the boat, and that is quite a soft setup compared to the states where sprint racing it the norm, for 5-6 laps and its all done in a minute and a half, if you are concerned with runtimes stay away from the big 1415/1515s and stick with the stock spec motors which will give you over 5 mins on the stock prop.
I moved on from RTRs before RTRs came along and as such I have had neither but I believe the Impulse 31 does have room for 4s2p but the AQ MC does not have room for 2p, 2p does not necessarily mean you can run twice as long though anyway as the extra heatsoak from that long runtime may be too much, those that race with 2p may be discharging less than 5000mAh in the minute or so that they are running for but need the 2p, to avoid large voltage drops on the high currents they pull and the weight to keep the boat on the water at the high speeds, while they may have the capacity to run for 3 minutes if they actually ran that long they would fry the motor or ESC.
Lots of boats.
fastelectrics.net
04.01.2012, 11:31 AM
http://www.minicatracingusa.com/vmono.html
Is this the same as the Tenshock Mono1? It looks to be the same one. It's weird how this webstie has everything else discontinued, not available or only one of a color left?
I think I'm going to take your advice, this looks like a bad ass little machine.
Wow those Riggers look like a ton of fun. Lots of torque coming from those boats.
Thanks again for the suggestions. I just need to sell my Ten-T now and I'll be good to go.
Nick
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
