Question???
AP Alex
AP Alex's Avatar
Question??? - 11.20.2012, 05:33 PM
Brushless LST2 or Revo G2 Which one is the best bang for your buck?
11.20.2012, 05:52 PM
Bashing or racing / durability or handling?
Not that the LST2 can't handle well from what I've seen, but a revo can own a truggy in the right hands, so...
AP Alex
AP Alex's Avatar
11.20.2012, 06:39 PM
Bashing and fun
11.21.2012, 10:34 AM
I'd probably say LST2 then- it's built like a tank so can handle more 'fun' without risk of damaging or bending the impossible to replace Gorillamaxx chassis...
traxxasbasher13
11.21.2012, 11:55 AM
While I agree the LST is going to be more durable stock, if you throw some RPM arms on the E-Revo and some different push rods and you have an almost bullet proof truck. I loved my E-Revo, I wish I still had it
11.21.2012, 05:41 PM
Diff's on the stock revo suck... get the LST
11.22.2012, 08:52 AM
+1 on that. If you are going to have "fun" w/no worries w/the Revo, the diffs and a whole host of other parts should be upgraded to be able to have a worry free bash session.
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
11.23.2012, 12:48 AM
What would you suggest for center shafts on an E-REVO? I already have LST diffs in mine and Summit shafts in the back, which have held up well. I have a converted 3.3 using an old 3906 E-Maxx transmission, so I don't think there is a standard length dogbone that will fit (E-REVO rear shaft is too long, front shaft is too short). Needs to be a somewhat narrow shaft so it won't rub on the bulkheads because the transmission output is not centered on the chassis. Are there any drive cups out there that won't get the little dents where the dogbone rides?
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
11.23.2012, 12:13 PM
Tricky one. If you can work out exactly how long the shafts / dogbones need to be ( upto -5mm say ), then chances are there may be some 1/8 buggy, truggy or MT ones the correct lengtt. Just requires a bit fo searching around- googling the length you need often brings up several options I've found when it comes to random lengths.
As for drive cups, even hardened steel ones seem to develop little dents over time- not much you can do about it, even if the drive pins are a perfect fit with no slop. I'd consider them an item that needs replacing every so often, just like slipper pads and clutch shoes etc etc.
