Question about castle warranty
CerberusVI
CerberusVI's Avatar
Question about castle warranty - 03.09.2013, 02:33 PM
so I bought a new mamba monster v3 august of last year. 2 months before my warranty expired I ran into issues with my esc and sent it in and received a new esc with my 6.5mm bullets in the box.
Well now I'm having issues with the new one I received, really bad cogging, struggles with any motor I have (1717,1512,1520) on 4s to 6s 40c 5000mah batteries. I pulled it out of my truck fearing it was gonna let out the magic smoke. I checked all my solder joints and tested the motors with my other mmv3 in my MT and everything is fine.
My question is when receiving a new esc does it doesn't extend the warranty at all does it? I'm not too thrilled to shell out another $76 for a out of warranty repair and shipping.
Setup;
Mugen mbx5t prospec
Mamba monster
1520
Zippy 5s 40c 5000mah
Geared: 16/46 for roughly 43mph
brainanator
brainanator's Avatar
03.09.2013, 03:49 PM
Have you tried different firmwares? I know that the newer ones seem to have poor start up procedures. I think 1.24 is the most popular, not a 100% sure on that, but someone who knows better than I will come and chime in shortly.
Is this a new issue or have you changed something? I mean, was it working great and then suddenly started cogging and struggling, or has been this way since you've gotten it, or did you change something recently? (gearing/firmware/tires/rebuild diffs/bearings/water running/etc)
CerberusVI
CerberusVI's Avatar
03.09.2013, 03:54 PM
It is a new issue. I have tried different firmwares but I always stick with 1.24 for the start up issues. I havent changed anything. All my truggy tires are about the same size. Gearing hasn't changed. All my temps are usually really good and I never run my gear in wet grass or weather for fear of water issues.
03.10.2013, 09:39 AM
How old is the replacement?
Just to clarify did you shell out $76 before as you say you sent the old one in before the warranty expired.
CerberusVI
CerberusVI's Avatar
03.10.2013, 12:44 PM
Double post
CerberusVI
CerberusVI's Avatar
03.10.2013, 01:00 PM
I just looked at my invoice from castle and it says 6/29/2012. No I didn't pay before because I was still under my 1 year warranty. I bought it brand new from a main on 7/30/2011.
It may seem like its been a long time but I haven't even had much run time on any of my rigs due to work and lovely western Washington weather. I have maybe 6-9 5s runs and 3-5 6s runs, That's guesstimating high also
Thomas Porfert
Thomas Porfert's Avatar
03.12.2013, 10:38 AM
The warranty is good for 1-year from the original date of purchase. So if we replaced it under warranty in 2012, but was purchased in July of 2011 then it would be out of warranty. If you paid the $70 non-warranty replacement you would get a new ESC and new one-year warranty; or you can upgrade to the Mamba Monster 2 for $105.
Thomas Porfert
Tech Support
CerberusVI
CerberusVI's Avatar
03.14.2013, 02:00 PM
Well it looks like I'm out of luck and on my own with this one...maybe its time I try a hobby wing or hk 150a esc in my rigs
nastety92
03.14.2013, 02:17 PM
I wonder if someone from HW or HK would reply to one of your threads if you had a problem?? Castle isn't doing anything wrong here, rules are rules.
Nick
Tamiya TRF801Xt-e
03.14.2013, 04:22 PM
If you haven't used your truck that much are your batteries ok?
There is a limit to any warranty - at this point your a long time since your original purchase date and a non warranty replacement is still only $70.
CerberusVI
CerberusVI's Avatar
03.14.2013, 04:38 PM
I have tried all the available firmware through castle link, I have tried my 1717, 1520 and 1512, As well as my turnigy 2560 6pole and they all do the same. My batteries do get used in my truggy and I don't have any issues with my other mmv3 and 1520 in that setup
I haven't had time to go through all my barriers and esc's to resolder all my castle 6.5mm bullets. I will try and resolder everything tonight and report back
CerberusVI
CerberusVI's Avatar
03.15.2013, 07:08 PM
Took some time, but I went and re soldered my 5s, 6s, mamba monster and my 1717. Still have the same issue. Ill have some time on Monday to put it all back together and try to take my truck for a quick test run.
I also tried my traxxas 2.4ghz radio as well ad my flysky gt3b and recalibrated the esc both times and still have problems.
ksb51rl
03.19.2013, 01:12 AM
Have you thought of eliminating the steering servo as a source of the problem? Bad ones can make ESCs do some funky things.
CerberusVI
CerberusVI's Avatar
03.20.2013, 03:34 PM
I tried different servos last night, solar d772, orion, ae s200mg, traxxas 2055, 2018, I tried a couple others too. They all did the same thing. I tried driving it again and playing withdifferent pinion gears from 10,12,13,14,16 and none of that helped. I'm still very cautious when I try driving it because I'm scared its gonna let the magic smoke out and damage the rest of my rig in doing so.
CerberusVI
CerberusVI's Avatar
03.20.2013, 03:36 PM
Also forgot to mention I added a brand new castle 10a bec to see if that helped. It reluctantly did not.
