How large outrunner needed for dd-mt4 g3 mt ?
speedy
How large outrunner needed for dd-mt4 g3 mt ? - 05.10.2013, 02:58 PM
if i whant to replace the center diff on my tt-mt4 g3 truck with a outrunner how big does it need to be ?
http://www.carrocar.se/produkter/p-b...1-tt6401-f101/
05.10.2013, 03:16 PM
Check this thread out...
http://rc-monster.com/forum/showthread.php?t=8536
speedy
05.10.2013, 05:24 PM
If i just would replace the 40x75 2000kv 4-pole stock inrunner with a outrunner would a 42/50 840kv motor be enough ?
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.10.2013, 10:45 PM
What's 40x75? What is 42/50 mean?
As far as what brand of motor you should use, check out Scorpion brushless motors, IIRC, the 40xx S2's are the newest (not even sure if they are out yet) and have been designed with the best high temp. magnets, high temperature wire and small mil core material thickness (0.2mm stator steel). These things are very efficient and just as important, they will be tough.
speedy
05.11.2013, 02:42 AM
The innrunner motor i 40mm in diameter and 75mm long and thenoutrunnr is 42x50mm
(the stator in the outrunner is 35mm in diameter and 26mm thick annit has 12poles )
