Robin
Brokenparts
Robin - 08.06.2013, 05:24 AM
My emaxx is coming ever closer to completion. Can you set me up for an HVC chassiss w/ bukless bulks and a 1717 mount? Will the mono block work with this?
Txt # 443 425 6194
Running one 5s 3800 reedy and it won't stay together.
WheelMan
Do Epic Sh!t
WheelMan's Avatar
08.06.2013, 03:05 PM
You need to go here to PreOrder the standard bulk HVL. And as far as it looks, you can still get in on the discounted preorder price too. But I would have to guess that is going to end any day now.
The monoblock will not work with the HVL chassis. The length of the HVL was designed to be equal to a Lightning/Thunder chassis with a monoblock anyways, so it's already extended, and there is no need for further lengthening.
He has mentioned that the production HVL's should be able to fit a 1717 or 1520 just fine. No alternative motor mount is offered or needed.
-Travis
Adults are just kids, with money.
Common sense, is not so common.
MonsterMaxx
Owner of Unlimited Engineering
08.09.2013, 04:59 PM
Wheelman is correct
