Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
Which Ultramaxxed Generation is Which?
dda01015
Question Which Ultramaxxed Generation is Which? - 06.27.2006, 01:01 AM
Does anyone know the difference between Ultramaxxed Gen II and Gen III?
I have a set with steel pins between the drive slots, and a set without. Which is which?
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
06.27.2006, 08:20 AM
the gears thet do not have the steel pin insets are gen II, while the ones that do are the gen III's....(the pins are inserted into the 1st/2nd gears where the shift dog pins make contact.
  Send a message via MSN to sjcrss
Serum
Serum's Avatar
06.27.2006, 10:41 AM
gen III uses brass idlers
sjcrss
sjcrss's Avatar
06.27.2006, 11:25 AM
actually serum.... the gen II and the III used the brass idlers.....gen I where just the gears and the shift dog w/ ue idlers...but everything was hard anadized teflon coated (i think that what Dan used).....I was one of the testers for the Gen II gears....and then after that Dan made another improvement and added the steel pins..for a steel-to-steel contact......if you dont belive I was a tester goto this link....I'm on the bottom of the page...
http://www.thewebmine.com/testimonials.htm
Serum
Serum's Avatar
06.27.2006, 11:34 AM
I was not saying the gen II didn't used brass gears, i was only telling what i knew. Which is that the genIII's use brass idlers.. there was this discussion going on here earlier saying that it wasn't brass, while i was pretty sure it was.
I don't doubt a word you are saying sjcrss.
What setups are you currently using?
neweuser
neweuser's Avatar
06.27.2006, 11:50 AM
I think he just put in the gen III's if i'm not mistaken.
Serum
Serum's Avatar
06.27.2006, 11:52 AM
I meant brushless setups.
