Upgrading the stock bulks..
Serum
Serum's Avatar
Upgrading the stock bulks.. - 08.10.2006, 10:43 AM
With a few pieces of aluminum, i beefed up my stock bulks a bit.
Front;
Rear;
It works like a charm. So far, i broke a front arm, and the rest is going strong.
Procharged5.0
Procharged5.0's Avatar
08.10.2006, 01:02 PM
Interesting.
Mikey
Buggy Man
Mikey's Avatar
08.10.2006, 01:18 PM
does anybody make t-maxx diffs that will hold oil because i know first hand that the stock ones do not.
  Send a message via Yahoo to Mikey
Serum
Serum's Avatar
08.10.2006, 01:29 PM
Nope.. Too bad, no one does..
That's the downside of this lightweight truck. You got to keep traction out of the corners.
coolhandcountry
coolhandcountry's Avatar
08.10.2006, 02:08 PM
The new 3.3 diffs may. I don't know for sure or not. Can any one say for sure.
Serum
Serum's Avatar
08.10.2006, 02:20 PM
Yeah, i know for sure they can't. They are the exact same as the stock diffs/ringgear.
The only thing it needs is a small notch for the o-rings.... Come to think of it.. Where is my lathe.......
squeeforever
squeeforever's Avatar
08.10.2006, 05:11 PM
I have been told that with a little finessing you can get Revo gears in the Maxx diff cases. Not sure if its true or not.
Serum
Serum's Avatar
08.10.2006, 05:12 PM
I dunno, they look a lot like eachother. I have got a revo cup here, but no ringgear. Can't test it out.
Revo gears, Maxx Diff Cases
Procharged5.0
Revo gears, Maxx Diff Cases - 08.10.2006, 05:43 PM
It is possible but it requires a bearing spacer. The maxx large side bearing is a 10x15 vs the revo's 8x16. One of two things has to happen. Either machine out your maxx housings to accept the 16mm bearing or have a 8x10x4 adaptor bushing made to fit the 10x15 bearing on the 8mm side of the diff cup.
Serum
Serum's Avatar
08.10.2006, 05:48 PM
Yeah, 15X8 bearings are hard to find. I guess a 8/10mm adaptor is the easiest to make then. But then you would need a lathe, and with that lathe, you could also make the small notches for the o-rings in the cup/ringgear. (thinking while i am typing...) which should work just as well.
