Feigao brushless pede
sleepy23
sleepy23's Avatar
Feigao brushless pede - 08.23.2006, 10:10 PM
Quick gearing question. I relocated my feigao 6s and mgm over to the new pede i bought. my question would be what could i safely gear that sucker to get the best performance?
Thanks
S^3: everyone wishes they could design modifications like these.
sleepy23
sleepy23's Avatar
08.25.2006, 10:02 PM
so no one knows anything about a brushless pede??
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
08.25.2006, 10:15 PM
This motor can only be geared according to the quality of your packs. If you have better packs, use a bigger pinion. Otherwise you will get poor performance with high gearing if your packs aren't up to par. Don't worry about heat. Basically it will heat up a certain amount no matter what gearing is used and no more than that until you gear really really high. Peak efficiency happens at above 100 amps.
Area 52 Ranch Raceway
T.R.C.R.
sleepy23
sleepy23's Avatar
08.28.2006, 07:08 PM
anyone know of a better motor that wold run on the mgm80 and run great in a pede.
squeeforever
squeeforever's Avatar
08.28.2006, 07:15 PM
I would go for a Neu or Lehner 1920
coolhandcountry
coolhandcountry's Avatar
08.28.2006, 08:24 PM
You could get a mamba maxx 5700 motor. Try it out on the mgm.
swiftneed
swiftneed's Avatar
08.28.2006, 08:28 PM
the novak ss5800,is it as fast as the mamba i know the novak is smooth but do u also need a ubec I would like to take out my novak and replace it with something faster but longer runtime 7 cells
squeeforever
08.28.2006, 10:50 PM
No, with a Novak you don't use a UBEC. I would go for a Mamba controller for sure.
sleepy23
sleepy23's Avatar
08.29.2006, 01:32 PM
humm, i will give it some consideration. I am not looking for blistering speed ( i have several other trucks for that). I am looking to keep it around 40mph which is where i am now, but may some more torque to keep the big meats moving.
neweuser
neweuser's Avatar
08.29.2006, 01:44 PM
I would go with the neu and mamba combo in the pede. It would be nice to have someone try the mamba set up in one though! LOL
coolhandcountry
08.29.2006, 03:02 PM
The neu motors are fatter than a 540. I not sure if you can fit them every where you would a 540.
sleepy23
sleepy23's Avatar
08.29.2006, 11:04 PM
the pede is sporting a custom tranny case and motor plate, fitting a new motor is not a problem.
