Someone double check this quickly please
GeeReg
GeeReg's Avatar
Someone double check this quickly please - 08.31.2006, 06:13 PM
I just need someone to check this quick as I'm new to lipos. I just got 2 lipo packs to run in my Nitro MT. They are 2200mah 3S2P. To charge these I want to make a harness to run them in parallel to my charger, and charge at 4.4a right? TIA.
RC10T2 - Novak SS5800 - 7-cell GP3700
HPI RS4 Nitro MT - Mamba Max 5700 - 2S 5500mah Lipo
MRC Thunder King - Mtroniks Truck ESC + Feigao 9L - 3S 6000mah Lipo
squeeforever
squeeforever's Avatar
08.31.2006, 06:16 PM
Yes. Just make sure to balance them.
GeeReg
GeeReg's Avatar
08.31.2006, 06:18 PM
So is it a better idea to charge them separately with the balancer for the first time?
Gustav
Gustav's Avatar
08.31.2006, 06:53 PM
I'd say so,i sometimes charge 2 packs together to about 90%,then charge them to full individually attached to a balancer.The good thing about Lipos is you can charge them the night before.I sometimes run mine days after the charge,i just check them on the charger before i run them.
GeeReg
GeeReg's Avatar
08.31.2006, 07:51 PM
Ok thanks guys. I balanced both with my LBA6. One didn't need any and the other took about 2 min.
jhautz
jhautz's Avatar
08.31.2006, 08:10 PM
If you are going to charge both packs together in parallel, they need to be balanced to each other as well. Make sure the voltage of the 2 ballanced packs is exactly the same before you charge them in parallel.
to make it...
or break it...
Silent...But Deadly
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.01.2006, 03:49 PM
You don't need to fully charge a lipo pack. In fact it's better not to. Just unplug it when it reaches 4.2 volts/cell volts. That is usually when it's 90% full.
Area 52 Ranch Raceway
T.R.C.R.
