Super fast question
GorillaMaxx360
GorillaMaxx360's Avatar
Super fast question - 12.25.2006, 07:18 PM
Which of the HB diffs that mike sells the pro version($65) or the regular ($62) has the lower gear ratio. If i am not mistaken on ratio is in the 4.0-5.0 range and the other is like 3.3 or somewhere in the 3.0's rnge which is it the pro or the regular that has the lower ratio and what is the exact ratio. Thanks
squeeforever
squeeforever's Avatar
12.25.2006, 07:40 PM
Ok, you want the non-Pro. The Pro has the 4.3:1 ratio and the standard has the 3.31:1 ratio. The Pro's come in the truggies for a lower over-all gear ratio so they don't have to run a huge spur. The 4.3:1 will give you to low of a over-all gear ratio. With the 3.31:1 diffs and slipperential, you will already be using a pretty large pinion.
GorillaMaxx360
12.25.2006, 07:57 PM
ok thanks thought so just making sure
coolhandcountry
coolhandcountry's Avatar
12.25.2006, 08:45 PM
Unless you going to a crawler or something.
