MM on 5s no go !!
ALL BRUSHED UP
MM on 5s no go !! - 02.04.2007, 04:05 PM
Mamba works great on 4s but will not go on 5s steering works but thats it.It worked the first time when we plugged 5s in but had very little power.switched to 4s worked great then back to 5s this time motor will not even move.Help need 5s like everybody else :012:
Sylvester
Sylvester's Avatar
02.04.2007, 04:07 PM
Welcome to the forums!
Are you using a UBEC or receiver pack? The MM was proven on 4s but not the greatest on 5s.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
02.04.2007, 04:09 PM
welcome, all brushed up!
might need mgm compro or quark esc? or MMM?
losi 8ight-t
xray xt8
Sylvester
Sylvester's Avatar
02.04.2007, 04:17 PM
Even a 9920 would be a good esc.
Losi 8ight e
Serum
Serum's Avatar
02.04.2007, 04:26 PM
Welcome to the forum all brushed up.
Basicly, the mm isn't meant for 5S. Some users have got luck with it on 5S though. If you want to use it on 5S, do you use a UBEC/external receiver pack? if yes; did you removed the red wire from the three wires going from the speedo to the receiver?
ALL BRUSHED UP
02.04.2007, 07:41 PM
I am using the ubec,removed the red wire I just have very little power and if I punch it it just stops. I can only get about 10% power out of the 5s batterys.What gives?
02.04.2007, 07:49 PM
Basically, it is made for no more than 4s. If you can get it to work on 5s, consider it a bonus. Kinda like computer overclocking; some CPUs can do it better than others - the only thing the manufacturer will guarantee is that it will run as specified.
Maybe you can play with the timing and throttle control to make the ESC not quite work so hard. What motor are you using?
Nick
COOKIES!
Nick's Avatar
02.04.2007, 07:50 PM
Make sure Lipo cut-off is on Auto or Off!
Side to that: Can the MM run on 4s with no Ubec?
~ Nick.
Bomb-Proof
02.04.2007, 09:22 PM
Set LVC at around 15.5v, and plug it all up. It should initialize fine, and give the yellow light I believe. You may only get a second or two of power, if so...turn off switch and back on. Yellow light should be back. Then give it slight throttle and hold it at that position for a while. It should act alright once the voltage drops to around 20.4v. That should get you running though, its a pain...but its not made for 5s.
Sylvester
Sylvester's Avatar
02.05.2007, 09:31 AM
It would over heat without a UBEC, anything over 3s should use a ubec.
Losi 8ight e
Serum
Serum's Avatar
02.05.2007, 04:45 AM
Sounds like an LVC problem to me.
