Brushless 4-tec
akratz1
Brushless 4-tec - 03.28.2007, 11:14 AM
I need a brushyles setup for this 4-tec i got off ebay. Would like to spend as little as possible, what should I go with. Also will anything need to be upgraded due to the performanc increase?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.28.2007, 11:17 AM
I don't know what the limits are for the 4-tec... I would not go too extreme with this car. The nitro version was built to take soem serious power but not sure about the electric one.
A Mamba Max would be a great choice and it's also one of the cheapest. THe motor choice depends on what battery you will be using... and what type of driving you want to do...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
akratz1
03.28.2007, 11:26 AM
For now just using NiMH, primarily driving for fun but want some good speed.
glassdoctor
TEAM FUSION
03.28.2007, 11:35 AM
I would say drop in a MM 5700 or 6900 system. Both will be fast... ;) They have been going for under $200 lately even my LHS had one for a stupid cheap $179 a couple weeks ago.
But even at $212 it's the best deal going....
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Looneybin
03.28.2007, 12:13 PM
i would n't expect too much from it. i had a stock one and managed to strip a front differential plus its belt drive with no way of tightening tension. i think a brushless would destroy the drive train in one of those.
Soya
03.28.2007, 11:38 PM
The electric drivetrain is almost identical to the nitro version.
jnev
jnev's Avatar
03.29.2007, 12:40 AM
If the drivetrain is the same, then you can put pretty much any motor in there.... I'd recomend the Mamba MAx 5700 on 3s if you really want a lot of speed.:027:
crazyjr
crazyjr's Avatar
03.29.2007, 04:13 PM
If you're going to go brushless the novak would be better. I tryed a 10 turn triple brushed in mine, it split the diff and spit balls at me, literally stripped the diff halves
There is a difference, the 4 tec electric is almost identical to the RS4 where the nitro 4 tec is a three belt system like an R40
Looneybin
03.29.2007, 04:37 PM
^^^^ exactly. the diff halve are really weak.
bigboi146
Multi Tasking
bigboi146's Avatar
03.29.2007, 04:50 PM
I wouldn't go brushless without upgrading the differentials to the pro ones that are found in the nitro 4-tec.
seth556
RC-Monster Silicon Carbon
seth556's Avatar
03.29.2007, 05:40 PM
The nitro diffs fit without any problems. I would upgrade to them and then go brushless. And the nitro diffs only cost somewhere around $25.
  Send a message via AIM to seth556
Soya
03.29.2007, 09:09 PM
oh, I thought it was a 3 belt. my bad.
akratz1
03.30.2007, 01:06 AM
So upgrade the diffs and i'll be in good shape. Would i be able to go with the higher 7700 then or whats really the difference in them.
