c50 MAXX VS neu 1515 1y
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
c50 MAXX VS neu 1515 1y - 04.07.2007, 09:51 AM
Hi guys any thoughts on the difference between these motors it will be for racing in my g2r revo on maxamps 8000mah 4s lipos on my quark. If ever I will use it for my mgm 24160, can i use the NEU 1515 1y for 6s lipos? without any heating problems? thanks
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
GriffinRU
04.07.2007, 01:13 PM
Big Difference,
C50MAXX is an 8L (35.8mmx51mm) version with heatsink while 1515 is close to XL (39.5mmx68.58mm).
Kv is also quite different...
6S for 1Y Neu 1515 is too much, I will go with 2Y or 2.5D.
In REVO C50 MAXX will be kind of weak choice, while NEU 1515 would be nice.
luvsrc
luvsrc's Avatar
04.07.2007, 02:23 PM
Thanks Griffin,Is hacker XL motors has a lesser torque or power than the NEU 1515 series?
GriffinRU
04.07.2007, 02:45 PM
You welcome,
By dimensions they should be very close to each other in terms of Power, but Neu being 4-pole motor has more torque at lower RPM by definition.
In addition Hacker rated their C50 XL-cans at 60A while Neu motors rated at higher currents, which means more torque again.
So, by all means same Kv motor from Neu will be 5-10% better then Hacker. Do not forget efficiency.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.07.2007, 03:50 PM
Actually the C50 Maxx is not an 8L... it's a 12s!! :) Same kv as an 8L though...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
GriffinRU
04.07.2007, 04:07 PM
Correct!
I was thinking about 8L while dimensions put from S-can. Bottom line it is not a motor to compare with Neu 1515 series.
Serum
Serum's Avatar
04.07.2007, 04:50 PM
the neu will have got TONS of torque compared to the relative weak hacker.
aim for the 30-35000rpm.
