E-CRT Finally Done
Sower
Sower's Avatar
E-CRT Finally Done - 05.07.2007, 01:47 PM
Ok guys, I've shown some prelims on this thing in my other thread, but it's fully finished now so I thought I would post some pics for you guys. Actually it's more for me since I'm so thrilled with it! :027: But hey, if you guys enjoy it - all the better! Take a look and let me know what you guys think.
ID:	2876   Click image for larger version
ID:	2877   Click image for larger version
Sower
Sower's Avatar
05.07.2007, 01:53 PM
Here's a few close up shots for you too:
ID:	2879   Click image for larger version
ID:	2880   Click image for larger version
MetalMan
MetalMan's Avatar
05.07.2007, 03:51 PM
Looks great! Very tidy, and I like the look of all that free space :). Is your battery tray u-channel with angle pieces at the end?
1bhutch
05.07.2007, 03:58 PM
crap look at all that extra room re u sure u hve every thing on it to run it
BJE
05.07.2007, 04:28 PM
Your CRT looks great. One question though, how did you make the battery tray?
Sower
Sower's Avatar
05.07.2007, 05:41 PM
Hey guys, thanks! The battery tray was an idea I stole from someone here on the forums. Just can't remember who :002: I ended up modifying their design a little. Instead of velcro for the top support, I used CF and body pins.
Basically the tray is two pieces of 1"x1" angle from Graphite Elegance. You put the two together, and then use a smaller section of it at each end. Then I used two battery posts for the top strap of CF. The posts act like a fastening bolt for the screw through the bottom of the chassis. It ended up working perfectly. Hope that all makes sense:032:
HotnCold
HotnCold's Avatar
05.07.2007, 06:53 PM
Nice conversion - good luck with her....
Hows that "Hope and Change" working out for Ya???
jnev
jnev's Avatar
05.07.2007, 06:52 PM
A little confusing, but I think I understood it.
Very nice and clean layout. I like it. Thats Mike's motor mount, right?
Sower
Sower's Avatar
05.08.2007, 02:25 PM
Well, I try :005:
Sorry about the write up. You know how it is, you write something out like that and it seems to make sense in your head . . . but only to you. Anyway, maybe a close up with the battery out would help. I'll see if I can post one for you and anyone else so they don't have to read my technical write up!
Oh, and no, that's not Mike's motor mount. I made that out of a piece of U-chanel aluminum so that I could mount the fan. I cut out a lot of the U-channel and ended up sculptin a round portion out for the fan blades - it works great.
bdebde
That's All Folks!
bdebde's Avatar
05.07.2007, 10:22 PM
So, how does that lehner run with the mamba max? Does it run cooler than the XL's? What lehner you running?
Sower
Sower's Avatar
05.08.2007, 02:42 PM
The Lehner I'm running is a 1940/10 hi-amp and it runs great with the MM. I can't compare it to the XL's since I've never had one. I can tell you this though . . . when I race it at our local track the motor gets up to about 115 and the speed control gets close to 130. That's all out racing until the 4350 goes dead - just under 20 minutes.
Sower
Sower's Avatar
05.08.2007, 04:28 PM
Here's the shots of the battery tray with no battery in it. Hope it's more clear.
ID:	2888   Click image for larger version
ID:	2889   Click image for larger version
Cartwheels
05.08.2007, 06:50 PM
Does your battery get warm at all. I've had trouble heat at the lipo with single pack conversions.
Sower
Sower's Avatar
05.08.2007, 11:49 PM
Nope. The lipo stays nice and cool. I'm using a Hyperion 4s 4350. What are you using?
Cartwheels
05.09.2007, 02:37 AM
In an older Ofna MBX basher, I've tried a few different packs. Flight Power 4s 3700 mAh, Poly RC 4s 3700, Kokam 4s 3200. I think in the future I will try higher mAh. It's fine until the last 15% of the pack. The newer packs may make a difference too.
