23mm adapters
Eccentric
23mm adapters - 05.19.2007, 04:54 PM
What is the difference between the Jammin X1 CRT and the Revo as far as the out drive shaft dia and drive pins. I'm sure some one here must have both trucks. The reason I'm asking is I would like to use these 23mm adapters. I like that the pin is captured by the o-ring.
wallot
wallot's Avatar
05.19.2007, 05:00 PM
jammin adapters go on the axle.
revo and other MT adapters mount on the 14mm hex
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
Eccentric
05.19.2007, 05:02 PM
Originally Posted by wallot
jammin adapters go on the driveshaft.
Right but I rather not have the plastic 14mm hex under the 23mm.
Sylvester
Sylvester's Avatar
05.19.2007, 05:31 PM
Get the Rdracing 23mm adaptors. www.rdracingproducts.com
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Eccentric
05.19.2007, 10:04 PM
I was looking into those too. The only thing is they are twice as much and
**At this time these hubs and axles only fit our axle carriers, part number REV105**
Which are another $100.
Serum
Serum's Avatar
05.20.2007, 04:07 AM
Yeah, you do need the knuckles with these.
If you want to use a 23 mm adaptor go dace, they are the best. The prolines for the revo don't use the 14mm hex, but they are rather weak and use an odd key.
crazyjr
crazyjr's Avatar
05.20.2007, 12:22 PM
I use prolines, at about half price. If you shim them right and use locktite they are good
Serum
Serum's Avatar
05.20.2007, 12:25 PM
I have got the bad experience with the proline that the pin will eat its way in the aluminum
Eccentric
05.20.2007, 12:37 PM
I have the Prolines and the material is soft. One of them wasn't cut right it was .025" undersized. I had to remove all the anodizing plus material so make that one fit. I think it just got setup wrong and someone wasn't checking them. Still I'm not happy with them.
