Shimming diffs in FLM Hybrid Bulks
Shimming diffs in FLM Hybrid Bulks - 09.28.2007, 06:22 PM
Is this necessary? and where do I get the shimms, can't find a HB # for them. I am guessing that they have a 8mm id and 10-12mm od?!
09.29.2007, 02:44 AM
No shimming necessary then!
I will hold all of you accountable if my diffs strip out!
Serum
Serum's Avatar
09.29.2007, 04:42 AM
They require allmost no shimming, (i would like to have a little more room in them though) i think i only shimmed the pinion gear in mine.
I used Kyosho shimms, they come in 8mm ID, and .1, .2 and .3 mm thickness, and tamiya makes 10mm id shimms with the same thicknesses.
If you need cheap .5mm thick 6 or 7 id shimms, traxxas has these in teflon.
09.29.2007, 10:37 AM
Thanks Serum.
sapper_triple6
Student of RC-Monster University
sapper_triple6's Avatar
09.30.2007, 05:48 PM
I've been running mine without shims since the snow melted this spring and I checked them the other day. Absolutely no noticeable wear.
  Send a message via Yahoo to sapper_triple6
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.11.2007, 03:13 PM
Am I correct that id means in drive and od means out drive? Because I need to shim my pinion. It has too much play and will slide in a hit the cup. These would be 8mm in drive, correct?
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
11.11.2007, 03:47 PM
ID means inside of shim or circle
OD means outside of shim or circle
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.11.2007, 03:51 PM
Thanks. Since my pinion is sliding in I need to shim the outside near the dogbone cup right?
sjcrss
sjcrss's Avatar
11.11.2007, 04:04 PM
Thats correct, if it is sliding in and out, the pinion shaft needs to be shimmed between the bearing and the drive cup, also make sure you can maintain the correct tolerance inside the diff after you shim it
Bl E-REVO
Quark 125b
((2s2p)(4s)
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.11.2007, 04:15 PM
Thanks for the help. They are 8mm shims right?
sjcrss
sjcrss's Avatar
11.11.2007, 04:16 PM
that im not to sure of
Bl E-REVO
Quark 125b
((2s2p)(4s)
Ninmaxx
11.11.2007, 05:51 PM
Would these be the shims to use with HB 1/8 diffs?http://www.shopkyosho.com/product/pa...er=96644/410.0
And when using Revo stub axles what size shims would I need for those?
Btw about how many shims come in a kit?
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.11.2007, 07:54 PM
I got this reply from Rene:
"Yeah, that's an 8.
I got a set of kyosho shimms, 10 of each; .1 mm, .2 mm and .3mm.
I just PMed Rene. I think that is them but I am not sure.
sjcrss
sjcrss's Avatar
11.11.2007, 07:07 PM
Im not really sure, as I will be getting my cases this week my self, but I think I will be able to use the shims I have in my UE diff cases to help me out , if need be....but those look like the right ones, I'll let someone else pipe-in, to confirm this
Bl E-REVO
Quark 125b
((2s2p)(4s)
Ninmaxx
11.11.2007, 09:54 PM
I think those are it, they are the only
8mm on the site.
