Neu motor choice
david lamontagn
Neu motor choice - 10.01.2007, 11:04 PM
For my e-revo, want to upgrade to a high end motor.
I think to the neu, but wich one for 4s li-po setup???
Think about 1515 1Y, this is a good choice??
And is i'am better to take the smooth can or the fin can??
Is the fin can work with the RcMonster revo motor mount
Thank you!
jnev
jnev's Avatar
10.01.2007, 11:18 PM
The Neu 1515/1y (2200KV) is the exact motor I plan to put in my E-Revo. It should do perfect on 4s lipo.
I am assuming that the finned can will stay a little cooler because it will have more surface area to dissipate heat to, but the Neu is very efficient anyway, so I don't know if it is necessary to use the finned.
I am also wondering if it will work with the RCM Revo motor mount...
glassdoctor
TEAM FUSION
glassdoctor's Avatar
10.01.2007, 11:19 PM
yes
I would take the finned can... and I think it works fine with the mount.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
david lamontagn
10.01.2007, 11:40 PM
HTML Code:
Need to be certain before to order a $300 + motor
glassdoctor
TEAM FUSION
10.02.2007, 12:46 AM
true... I would want to be certain also. Someone here surely has been there done that, so hang tight.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
