Definitely going to need new diffs!
gcurtis2121
Definitely going to need new diffs! - 07.01.2005, 09:54 AM
Well, my rear diff is definitely stripped. It's kind of fun to watch the front tires balloon like crazy though!
Luckily, I've got about 4 extra diffs, I started stocking up on them a while back. Figured that with the 9L I would need them. Hopefully it won't go through them too fast.
I just ordered some of the aluminum cases from Mike, and I'll be ordering the diff cups and spyders soon as well. Those things aren't cheap though, so hopefully the diffs I have lying around will get me through until I can get what I need!
Serum
Serum's Avatar
07.01.2005, 06:36 PM
Did you also ordered aluminum diff cases (the part that goes around the complete diff/gears) those help you to keep your ringgear/pinion in one piece (two actually) and a set of shims to give it a proper mesh. That way, you can run your 9L without to much diff problems..
gcurtis2121
07.02.2005, 08:49 AM
Yep, ordered the aluminum cases from Mike yesterday. Actually, went ahead and got the upgraded gears for one of them. Figure I'll use the strong one in the rear and I can put some stock gears up front and they should hold for a while. Don't seem to get as much stress up there.
