slipper
auto2
slipper - 07.10.2005, 01:28 PM
maybe I had it a touch too loose? oH well live and learn.
is this an aftermarket slipper?
squeeforever
squeeforever's Avatar
07.10.2005, 01:40 PM
stock
auto2
07.10.2005, 01:52 PM
thanks. so that has to go.LOL!
Hey MIKE! do you make house calls???:cool:
squeeforever
07.10.2005, 02:23 PM
yea, that really needs to go. especially if you have brushless. i would recommend the strobe slipper or the robinson slipper. both are good. strobes a little better
auto2
07.11.2005, 05:20 PM
OK so I have the stock spur(66?) with a 13 tooth pinion. the strobe is going to end up 51 ? so I need a larger pinion....
strobe is 51 and robinson is 71?
maxxdude1234
maxxdude1234's Avatar
07.11.2005, 05:25 PM
wrong....you need a smaller one. I just worked out that a 13/66 = 10/51 almost exactly. Therefore you will need a 10 tooth pinion (Mod 1) with the strobe slipper.
auto2
07.11.2005, 05:36 PM
yea your right. I have to see if I have enough room to move the motor in enough in the adj slots. Maybe the robinson with a larger spur will be less work ah I guess it depends on what mike has in stock..
squeeforever
07.11.2005, 10:01 PM
the robinson is a 66 tooth
coolhandcountry
coolhandcountry's Avatar
07.22.2005, 08:07 PM
If you buy the robinson. Stay with the plastic spur. The metal spur 65tooth will wear out pinions fast.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
07.23.2005, 03:38 AM
yes, a metall spur is not good for non hardened pinions. They can be stripped in 1-2 drive sessions..
squeeforever
07.24.2005, 12:43 PM
are robinson pinions hardened?
