mamba max help
entjoles
mamba max help - 11.25.2007, 12:17 AM
today i reprogramed my mm to see if i could get rid of a problem
it didnt work
my problem is this....
when i go full throttle the lights are green / yellow at the same time
my other mm does not do this , what is the matter with it???
it works @ all green until i get to 3/4 throttle then both lights come on
i do have a battery that is in ? but it seems ok
set up is this , mm w/bec disabled and 9xl in a revo with 2 x 2s 5k maxamps, and a spektum radio system
thanks for any help.....
glassdoctor
TEAM FUSION
glassdoctor's Avatar
11.25.2007, 12:35 AM
All I can think of is to check if it's set to 4s... and try messing with the LVC. (disable it and see what happens)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
entjoles
11.25.2007, 01:01 AM
i will try that, and i may try my other esc. to see if its the mm, thanks
entjoles
11.25.2007, 05:48 PM
well those things didnt work
i will try to get the batterys charged and see if it does it when they are topped off
i tried it on 5s and it works fine, but i just bench tested it, although i am tempted to try it on 5s, i dont want to blow up the esc.
11.25.2007, 07:20 PM
What do those lights indicate in the manual exactly?...
entjoles
11.25.2007, 07:49 PM
green = throttle
yellow = neutral
red = brake
MetalMan
MetalMan's Avatar
11.25.2007, 09:21 PM
Try messing with your full throttle endpoint on your radio, and go through the MM's endpoint programming (full throttle, turn the ESC on, wait for beep, full brake, wait for beep, neutral, wait for beep, done).
